Mechanic woes
Mechanic woes
Postby KevGoat » Fri Oct 18, 2013 7:36 pm
This post is not so much a call for any help, as this kind of engine issue is almost impossible for someone at a distance to call. More of a venting of today's frustration really ...
Today I took my NB to the mechanics. Was originally only going to my local, but his answer didn't really fill me with confidence, so off to another for a second opinion, who proceeded to confuse me further and by the third I was ready to throttle someone.
For quite a while, my NB8A's engine has had a knocking sound at cold start up that goes away in a couple of seconds as oil pressure comes up. It's similar to the way the NA HLA rattle works but this is a deeper, heavier sound and these are solid lifters. It's been present now through two oil and filter changes. Plugs and leads have also been changed during that time. I've worked out it's from the rear of the engine, quite loud with screwdriver to my ear and on rocker cover, but it's been difficult so far for me to tell if more pronounced from top or bottom of engine. The engine's always very quiet at idle and through the lower revs, but knocks again under acceleration at 3000 rpm ... fine under deceleration ...
All three mechanics had a good listen and short drive to hear under load ...
Mech 1 says it's oil leak back, probably due to a faulty oil filter as they've had a few faulty ones recently ... :shock:
Mech 2 says it's probably piston slap, could be end bearings, but probably not, as it would probably have packed in by now, so just put up with the noise until it gets a lot worse then bring it back ... an awful lot of "probable's" :shock: ... anyway, not being very mechanically minded, I had never heard of piston slap and had to Google that one :?
Mech 3 says it's a worn cam ... :|
Now, some credit where it's due - not one of them charged me anything even though I asked each what I owed them for their time ...
However ... only conclusion after a day of driving from mechanic to mechanic ... I need a drink ... :frown:
Feels better :roll: ... off to open a bottle of red ....
Re: Mechanic woes
Postby NitroDann » Fri Oct 18, 2013 7:41 pm
Why dont you just put an oil pressure guage on it and see if it correlates with pressure then investigate the things that needs pressure?
JBT
Re: Mechanic woes
Postby JBT » Fri Oct 18, 2013 10:29 pm
Some 1999/2000 NBs had a problem with #4 thrust bearing failure. http://www.miata.net/solo/99miatathrustbearingfailure.html
Hopefully it's not your problem.
Re: Mechanic woes
Postby KevGoat » Fri Oct 18, 2013 10:39 pm
NitroDann wrote:Why dont you just put an oil pressure guage on it and see if it correlates with pressure then investigate the things that needs pressure?
If only NB's had a decent oil pressure gauge ... :frown:
Have read the mods for a "proper" gauge in NB's like the NA6's. Any other method to do this?
Re: Mechanic woes
Postby NitroDann » Fri Oct 18, 2013 10:41 pm
Buy a gauge and put it on, if its just for testing just plug it in and watch it.
Re: Mechanic woes
Postby KevGoat » Fri Oct 18, 2013 10:44 pm
JBT wrote:Some 1999/2000 NBs had a problem with #4 thrust bearing failure. http://www.miata.net/solo/99miatathrustbearingfailure.html
Hmmm ... thanks, interesting. Hadn't read that one. One positive that appears to offset mine is mostly early failure - under 20k but something to consider.
Re: Mechanic woes
Postby KevGoat » Fri Oct 18, 2013 10:47 pm
NitroDann wrote:Buy a gauge and put it on, if its just for testing just plug it in and watch it.
OK, do you mean just an ordinary dash type oil gauge (plus proper sender) or a special tool that plugs/screws in? Sorry Dann, haven't done this before ...
Re: Mechanic woes
Postby NitroDann » Fri Oct 18, 2013 10:48 pm
Yeah just go to supercheap and get a gauge.
Re: Mechanic woes
Postby KevGoat » Fri Oct 18, 2013 10:52 pm
NitroDann wrote:Yeah just go to supercheap and get a gauge.
Thanks Dann ...
While spending the $ I may as well get what I need to properly replace the useless on/off switch & gauge in the instrument panel :?
Re: Mechanic woes
Postby NitroDann » Fri Oct 18, 2013 11:16 pm
Yeah research and do the swap :)
A real gauge is nice.
project.r.racing
Re: Mechanic woes
Postby project.r.racing » Sat Oct 19, 2013 10:56 am
i have a cheapie in a forsale thread with a brass t piece so you can keep the factory gauge running.
Re: Mechanic woes
Postby KevGoat » Fri Nov 01, 2013 3:34 pm
Following up ... my suspicions have been confirmed ... big end bearing (#4 cyl) :(
So...qas told it is still fine to drive and could stay that way for a long time as long as don't go nuts on revs and keep an eye (ear ) on it. Been like this since April and I've done 3,000kms with it knocking without getting any worse. It's not a loud knock, just enough to be annoying at higher revs.
Looks like time to start considering some options ...
JBT
Re: Mechanic woes
Postby JBT » Fri Nov 01, 2013 4:36 pm
D'oh, it's probably that #4 thrust bearing thing. :(
Re: Mechanic woes
Postby KevGoat » Fri Nov 01, 2013 5:29 pm
JBT wrote:D'oh, it's probably that #4 thrust bearing thing. :(
I mentioned that to him and he's pretty sure it's not.
After having a really long, good chat on picking the car up (great to find an "interested" mechanic!) about my servicing habits etc - oil changes, what the old oil looked like, any metal showing, my driving style, how hard I rev etc etc - and adding the fact that it hasn't got any worse over 3,000 kms despite some attempts by me to "kill or cure" :roll: he also added consideration of possibly the gudgeon pin, another known fault in 98/99's.
But of course, no knowing for sure unless strip it down ...
He mentioned a 13B transplant ............ we eventually returned to some lesser form of reality .........
johnnyreble
Vehicle: NA6 - Supercharged
Re: Mechanic woes
Postby johnnyreble » Fri Nov 01, 2013 5:40 pm
I'd be inclined to get it done sooner rather than later, it may last a long time in that condition, but it could also do a bit of damage to the crank the longer it goes.
Supercharged NA6
