MX5 Humans,
Tried searching for this to no avail.
Pretty sure my Jap NA6 has neither, which models came with them?
Many Thanks,
Jeff
NA Aluminium Bonnet/Boot
- Vehicle: NA6 - Turbo
Re: NA Aluminium Bonnet/Boot
All came with aluminium bonnet, none came with aluminium boot from factory as far as I'm aware
Magnet will tell you what you've got.
What's with the mx5 humans thing? Just a way around saying hi guys / girls?
- Boyracer
- MX-5 Encyclopedia
There is a limited edition in Japan that had a alloy boot as well, you can get a after market steel bonnet that is way cheaper and heavier than the original alloy bonnet.
Thanks for the info guys, and yes I don't mean to assume that everyone in here is a dude.
Limited edition explains the alloy boot costs that I've seen...
- wassup
The aluminum boot lid you're talking about came off a M2 1028 model with a run of 300 in Japan
http://translate.google.com/translate?u=http%3A%2F%2Fwww.geocities.jp%2Fclubm2_hp%2Farchive%2Fcat28.html&sl=ja&tl=en&hl=en&ie=UTF-8
This is how it compares to a standard NA bootlid and its about half the weight too.
1990 NA6
Civic Type R
Civic Type R
Oh my. Cleanup aisle 4.
- Learner Driver
yup all mx-5's have an alloy bonnet, soft top nc's have an alloy boot as well ive heard,
alloy bonnet comes up nice with a polish
eunos90 wrote:Hi mxers I have an imported 1990 NA Eunos Roadster. Both bonnett and boot are standard aluminium. Thay certainly did things a bit different with their home market. Cheers Mike
Are you really really sure? Was there anything non standard on the car when it got imported?
- wassup
sailaholic wrote:eunos90 wrote:Hi mxers I have an imported 1990 NA Eunos Roadster. Both bonnett and boot are standard aluminium. Thay certainly did things a bit different with their home market. Cheers Mike
My thoughts too. The 1028 seems to be the only NA that got a factory aluminum boot. Easy enough to confirm. It should only weigh 3.5 kg
1990 NA6
Civic Type R
Civic Type R
eunos90 wrote:I have an imported 1990 NA Eunos Roadster. Both bonnett and boot are standard aluminium.
A number of people have thought that as it did get wrongly mentioned on various MX5 forums, but it's not usually the case.
Alloy Bonnet, Steel Boot on mine. Man I love that M2 Boot, but for 1500 bucks for a secondhandy I reckon I'd go carbon and pocket the difference.
