Whats this?
lizard
Whats this?
Postby lizard » Fri Oct 11, 2013 6:40 pm
Found this rubber hose behind my battery 2004 SE what is it ? :? where dose it go what dose it do :oops:
Juicy HiC
Re: Whats this?
Postby Juicy HiC » Fri Oct 11, 2013 7:19 pm
Believe that it helps vent your battery
Sent from my SM-N9005 using Tapatalk [url='http://tapatalk.com/m?id=10']now Free[/url]
Re: Whats this?
Postby Jeo » Fri Oct 11, 2013 8:02 pm
Yep, battery vent.
Re: Whats this?
Postby hks_kansei » Fri Oct 11, 2013 8:34 pm
It's supposed to be attached to the battery, on the top of the battery should be a plastic nipple thing near where the vent caps would be if it weren't a sealed battery.
lizard
Re: Whats this?
Postby lizard » Fri Oct 11, 2013 8:58 pm
hks_kansei wrote:It's supposed to be attached to the battery, on the top of the battery should be a plastic nipple thing near where the vent caps would be if it weren't a sealed battery.
Thanks all and thanks hks that makes sense as the SE has a sealed battery
Mr nanotech
Re: Whats this?
Postby Mr nanotech » Fri Oct 11, 2013 9:33 pm
That's what it's for but it doesn't make a difference what battery you have in your mx5 anyway. I had a normal sealed liquid battery in mine for 9 years and had no problems with it at all. As long as it fits, any battery is fine.
JBT
Re: Whats this?
Postby JBT » Fri Oct 11, 2013 9:48 pm
Just be aware that a battery that vents into the boot space could possibly cause an explosion if there was a spark - thus the vent tubes for the factory battery.
