na8 clubman headlight twitching???!
erecsean
Postby erecsean » Mon Oct 07, 2013 3:15 pm
Hey guys ive got a na8 clubman and it seems like the past few days the pop up lghts have been twitching. It happened today mainly. As i was driving to my girlfriends house, everytime i indicate, the light pops up for a quick second and goes back down. Any idea what could cause this to happen? Its really annoying! Cheers.
MrRevhead
Re: na8 clubman headlight twitching???!
Postby MrRevhead » Mon Oct 07, 2013 3:41 pm
It could possibly be the Headlight retractor (LA12) relay.
Check for corrosion or if possible, borrow/purchase one to troubleshoot whether that is the problem.
Other Mazda's around the same era (astina, 626 etc) could possibly use the same LA12 relay for a number of things, so worth a check.
Also, have a look for a relay under the dash, next to the indicator relay with the word 'retract' labelled on it.
Postby 93_Clubman » Mon Oct 07, 2013 4:17 pm
Also might be the headlight/indicator stalk contacts - a few of the NA6s have suffered from this for a few years, & now that the NA8 is getting to a similar age & wear, it's possible this might be the problem in your case.
Postby manga_blue » Mon Oct 07, 2013 4:22 pm
x2 with 93_clubman. The stalk is contacting the high-beam switch at the same time as the indicator.
erecsean
Postby erecsean » Tue Oct 08, 2013 12:45 am
i will give that a check on my day off on wednesday. cheers guys!!
erecsean
Postby erecsean » Tue Oct 08, 2013 4:58 pm
How do i check the stalk?
erecsean
Postby 93_Clubman » Wed Oct 09, 2013 4:28 pm
Remove the two halves of the steering column black plastic cover below the steering wheel hub.
Users browsing this forum: No registered users and 67 guests
