na8 clubman headlight twitching???!
Hey guys ive got a na8 clubman and it seems like the past few days the pop up lghts have been twitching. It happened today mainly. As i was driving to my girlfriends house, everytime i indicate, the light pops up for a quick second and goes back down. Any idea what could cause this to happen? Its really annoying! Cheers.
- MrRevhead
Re: na8 clubman headlight twitching???!
It could possibly be the Headlight retractor (LA12) relay.
Check for corrosion or if possible, borrow/purchase one to troubleshoot whether that is the problem.
Other Mazda's around the same era (astina, 626 etc) could possibly use the same LA12 relay for a number of things, so worth a check.
Also, have a look for a relay under the dash, next to the indicator relay with the word 'retract' labelled on it.
Also might be the headlight/indicator stalk contacts - a few of the NA6s have suffered from this for a few years, & now that the NA8 is getting to a similar age & wear, it's possible this might be the problem in your case.
x2 with 93_clubman. The stalk is contacting the high-beam switch at the same time as the indicator.
i will give that a check on my day off on wednesday. cheers guys!!
How do i check the stalk?
Remove the two halves of the steering column black plastic cover below the steering wheel hub.
Users browsing this forum: No registered users and 70 guests
