rear heat window need help
tescoking
Postby tescoking » Sun Oct 06, 2013 1:43 am
hi guys, i turned on the heat for the rear window, but the window seems didnt get heat up, anyone know why?
My 5
M1474
Vehicle: ND - Turbo
Re: rear heat window need help
Postby M1474 » Sun Oct 06, 2013 2:21 am
Plugged in?
GHETTOCET
tescoking
Postby tescoking » Sun Oct 06, 2013 8:33 pm
M1474 wrote:Plugged in?
Yes, but it doesn't heat up
My 5
Postby Magpie » Mon Oct 07, 2013 9:29 am
Does it have power? Fuse blown? Switch turned on?
taminga16
Postby taminga16 » Mon Oct 07, 2013 9:58 am
Check the cut out switch (follow the cable from the window) they sometimes gum up and stick.
Greg.
tescoking
Postby tescoking » Tue Oct 08, 2013 4:27 am
taminga16 wrote:Check the cut out switch (follow the cable from the window) they sometimes gum up and stick.
Greg.
do you have a photo of that, i don't know what you mean
My 5
tescoking
Postby tescoking » Tue Oct 08, 2013 4:30 am
Magpie wrote:Does it have power? Fuse blown? Switch turned on?
the switch ligth is on so i guess the fuse should be alright, and i didn't do anything related to power or cable lately
My 5
tescoking
Postby tescoking » Thu Oct 10, 2013 3:16 am
i found out the reason, the window did not heat up is because one of the connection is lose on the window
My 5
taminga16
Postby taminga16 » Thu Oct 10, 2013 9:44 am
tescoking wrote:i found out the reason, the window did not heat up is because one of the connection is lose on the window
Well done.
Users browsing this forum: No registered users and 62 guests
