rear heat window need help
- tescoking
hi guys, i turned on the heat for the rear window, but the window seems didnt get heat up, anyone know why?
- Vehicle: ND - Turbo
- tescoking
Re: rear heat window need help
M1474 wrote:Plugged in?
Yes, but it doesn't heat up
Does it have power? Fuse blown? Switch turned on?
- taminga16
Check the cut out switch (follow the cable from the window) they sometimes gum up and stick.
Greg.
Greg.
- tescoking
taminga16 wrote:Check the cut out switch (follow the cable from the window) they sometimes gum up and stick.
Greg.
do you have a photo of that, i don't know what you mean
- tescoking
Magpie wrote:Does it have power? Fuse blown? Switch turned on?
the switch ligth is on so i guess the fuse should be alright, and i didn't do anything related to power or cable lately
- tescoking
i found out the reason, the window did not heat up is because one of the connection is lose on the window
- taminga16
tescoking wrote:i found out the reason, the window did not heat up is because one of the connection is lose on the window
Well done.
Users browsing this forum: No registered users and 59 guests
