Cam angle sensor failed?
JBT
Re: Cam angle sensor failed?
Postby JBT » Tue Sep 24, 2013 8:09 am
It will be hard to get a steady timing indication if the idle speed is fluctuating. The diagnostic box TEN and GND pins need to be bridged to set the base idle. If you can't get a steady idle then you have some other issue like a vacuum leak or fuel/air inconsistency (ICV, IAC, MAF, Intake Butterfly Seal, intake plumbing leak etc.).
Postby 93_Clubman » Tue Sep 24, 2013 11:14 am
mx5lover wrote:Since I replaced the engine, then my car had the idle problem. I did replace the coil pack, TB and also O2 sensor, but problem still there.
OP's idle problem:
viewtopic.php?f=29&t=53556
Which started after 1.6 for 1.6 engine swap:
viewtopic.php?f=44&t=44033&p=559478#p559478
mx5lover
Postby mx5lover » Sat Sep 28, 2013 5:29 pm
This is the linked for my car's idle video,any one know how to post the
video here?
http://www.youtube.com/watch?v=Ldg_g-kj ... e=youtu.be
mazmad
Postby mazmad » Sun Sep 29, 2013 8:13 am
Yeah you need to use the 'youtu' button above and insert into it the actual url for your vid (youtube have made it a couple more steps to get this now) As for your idle issue. No idea. :shock:
