hey guys i have got the first nut off the clutch master cylinder but am unsure how to get to the next.
it seems like its inside the fire wall?
this is the one i am talking about.
this one i have got to fine.
URGENT how to get to clutch master cylinder second nut
- 16bit
- plohl
Re: URGENT how to get to clutch master cylinder second nut
If you get under the steering wheel and follow the clutch pedal up, you'll see it.
plohl
plohl
- 16bit
thankyou sir.
will go have a look now.
Dislocate your spin in 3 places so you can lay on your back, turn your hand inside out and grow another thumb and you will get it.
- plohl
deviant wrote:Dislocate your spin in 3 places so you can lay on your back, turn your hand inside out and grow another thumb and you will get it.
I find it easier to remove the seat....
Sent from my GT-I9100T using Tapatalk 4
plohl
plohl
- 16bit
i got it sorted.
fairly certain i cross threaded the hardline bolt on the slave cylinder.
its not leaking at least.
i will cross that bridge in 10 years when i need to replace it again.
Users browsing this forum: No registered users and 115 guests
