Megasquirt owners thread
- Locutus
Re: Megasquirt owners thread
MS3 + MS3X gives you the latest and greatest with built in VVT control. Less to build, more inputs & outputs than you can poke a stick at.
AFAIK the only advantages of buying MS2 are cost and ability to hack the firmware (MS3 is not open source).
- 16bit
does the ms2v3 tune and run off the wideband or do I need the narrowband too?
WB only is fine, it also autotunes but you still have to tune spark manually and watch the AFRs to make sure it never goes lean.
- 16bit
sweet, didn't want to have to get another bung if i didn't need to.
- gslender
16bit wrote:sweet, didn't want to have to get another bung if i didn't need to.
If you buy an innovate LC1 (which has two signal outputs) you can have 1 of them set to wideband for the standalone ms2/ms3 ecu or gauge, and the other set to narrowband (emulated) so that you can run the stock computer again without having to swap out the wideband o2 sensor and controller.
I thought lc1 was discontinued?
- gslender
sailaholic wrote:I thought lc1 was discontinued?
Correct. The LC2 replaces the LC1 and is essentially the same, but some places are still providing the LC1 at good prices, but yeah if you can't get the LC1 then the LC2 is now the way to go.
G
- 16bit
i have an lc1 now so that sounds optimal.
thanks everyone.
thanks everyone.
Just street tuned another on this morning.
From rough start and idle poor AFR's and no throttle response to gorgeous in an hour
PnP FTW!
PnP FTW!
Hey my MS updated, so I re-entered my full version code...
Where the hell is idle speed target map now?
And startup idle duty cycle?
Not much fun tuning idle with a screwdriver..? Was totally fine this morning, update.. now I cannot find idle map?
Basemap was simply set to warmup only. So the target curve wasn't bold, it was greyed out (the option box) All good now.
- Learner Driver
- Vehicle: NA6 - Turbo
Hey Guys,
Been running my turbo mx5 on MS3 for awhile now seems pretty solid but want to get some more power out of it. Anyone recommend some dyno places in Sydney willing to touch a MS3?
Nick.
Nick.
Pm me. I don't want to openly advertise the shop and piss the guys off.
- sabretooth
- gslender
sabretooth wrote:Hey gslender, do you sell MS3 bits and pieces?
Sure do.
