Tyre width advice for Rota RB's on an NA.
Kallaroo MX5
Postby Kallaroo MX5 » Wed Sep 11, 2013 10:20 pm
Hello all,
I have taken the plunge and bought a set of 15 x 7 +25 Rota RB's, I don't want to flare the rear guards and I have yellow speed coil overs and the NA is quite low.
Will I get away with 205's or should I play it safe and just stick with 195's?
If you have any pictures of your RB's on the NA that would be great to see how the tyre looks.
Re: Tyre width advice for Rota RB's on an NA.
Postby Jeo » Thu Sep 12, 2013 10:15 am
How low is quite low? How much camber are you running/want to run?
pcmx5
Postby pcmx5 » Thu Sep 12, 2013 10:37 am
Johnd on this forum has Rota's 15x7 35 et and Kings and Koni's set on middle perch(I think).He runs 205's and gets a tiny bit of rub on really big bumps(not enough to worry about) so I think you would definitely be better sticking to 195's .
You will find his car on the NA wheels section of this forum on page 16.EDIT that's where I found his post when I did an author search under Wheels and Suspension but it isn't on that page when I went to check on the forum using the topic and going to page 16, so do the author search.
Good luck with whatever you do,
Peter
Blip
Postby Blip » Sun Sep 15, 2013 11:32 pm
Kallaroo MX5 wrote:Hello all,
Hi Kallaroo, I've been looking into buying some RB's as well, with the same specifications. Would you be so kind as to post a few photos of the wheels fitted onto your/your mum's MX5?
Along with tire specs (did you go for 205's?)
Thanks heaps!
Brandon
1996 BRG LE NA8
baseballer wrote:Got back from the Vic club run with around 30 cars.
A red MX5 coming the other way must have RSI by now from all the waving he did.
Users browsing this forum: No registered users and 262 guests
