Cheap ebay 'Empire Performance' extractors anyone?
- Evil Panda
Re: Cheap ebay 'Empire Performance' extractors anyone?
Running a link between the plug and the sensor until my new one arrives.
Just soldered the tips, bent over and shrink tubed. Seems to be doing the job.
What headers were you running before you installed these? We're they OEM or aftermarket?
- Evil Panda
Oh sorry, thought I'd mentioned it in the first post.... they were some aftermarket ones.
Couldn't find a stamp on them, so no idea what brand.
But they were 4-1 like the OEM headers.
That's why I wasn't expecting a huge difference.
P.S. Dann's comments just became a lot clearer. My bad mate.
I had a look at installing the new Empire extractors today but realised there is a piece of the puzzle missing.
The Empire exctractor has a female opening for the pipe that runs off the back of the header near the firewall as below.
and on the factory header it is a male fitting as below.
What do you use to adapt these together and what thread size would it be?
On the upside I found my main exhaust leak. No gasket in the join before the catalytic convertor.
Wow that port is REALLY nice.
NitroDann wrote:Wow that port is REALLY nice.
Can't tell if sarcasm?
Block of egr all together
Are you trying to troll me subtly here Emily..?
I can tell sarcasm! (I am a sucker, Dan)
What does that port do?
It's where the exhaust escapes the engine and out the exhaust pipe.
It should be perfect and smooth for good power.
On a turbo car it doesnt make so much difference but its still important, in an n/a car its very important.
Doh, not that port Dan.. I know what the exhaust does. (and realise that this header is not that good)
I was referring to the EGR port but I used search and now understand.
Now to work out the size and thread to make a join.
just delete it man, 2 bolts and a plate on the inlet manifold, and a bolt to block the hole in the extractors.
- Fra66L
emily_mx5 wrote:just delete it man, 2 bolts and a plate on the inlet manifold, and a bolt to block the hole in the extractors.
There's a nice brass fitting from the Bunnings plumbing section that fits quite nicely - the thread is subtly different but nothing that some exhaust gasket putty stuff can't fix. Been there, done that.
The Green Meanie - Grace Green NB8A
Veilside - It's Japanese for UGRY!
Fra66L wrote:emily_mx5 wrote:just delete it man, 2 bolts and a plate on the inlet manifold, and a bolt to block the hole in the extractors.
Do you recall the size fitting?
I just got a 15mm male to male but it is too small so thinking it must be 20mm.
- Fra66L
Sorry, no I don't. Working on the other side of the Pacific at the moment so no way I can check either
- Evil Panda
Wow.... they look nothing like the set I got.
My ports were nice and smooth... I took one little edge off with the Drimmel, other than that they were schmick.
I take it this is not for an NA6?
Are these a secondhand set that have been repaired?
