Cheap ebay 'Empire Performance' extractors anyone?
Evil Panda
Re: Cheap ebay 'Empire Performance' extractors anyone?
Postby Evil Panda » Thu Aug 22, 2013 10:50 pm
Running a link between the plug and the sensor until my new one arrives.
Just soldered the tips, bent over and shrink tubed. Seems to be doing the job.
spikes
Postby spikes » Fri Aug 23, 2013 11:10 am
What headers were you running before you installed these? We're they OEM or aftermarket?
Evil Panda
Postby Evil Panda » Fri Aug 23, 2013 2:20 pm
Oh sorry, thought I'd mentioned it in the first post.... they were some aftermarket ones.
Couldn't find a stamp on them, so no idea what brand.
But they were 4-1 like the OEM headers.
That's why I wasn't expecting a huge difference.
P.S. Dann's comments just became a lot clearer. My bad mate.
Snowmotion
Postby Snowmotion » Sat Sep 14, 2013 8:57 pm
I had a look at installing the new Empire extractors today but realised there is a piece of the puzzle missing.
The Empire exctractor has a female opening for the pipe that runs off the back of the header near the firewall as below.
and on the factory header it is a male fitting as below.
What do you use to adapt these together and what thread size would it be?
On the upside I found my main exhaust leak. No gasket in the join before the catalytic convertor.
Postby NitroDann » Sat Sep 14, 2013 9:00 pm
Wow that port is REALLY nice.
emily_mx5
Postby emily_mx5 » Sat Sep 14, 2013 9:15 pm
NitroDann wrote:Wow that port is REALLY nice.
Can't tell if sarcasm?
Block of egr all together :)
Postby NitroDann » Sat Sep 14, 2013 9:22 pm
Are you trying to troll me subtly here Emily..? :P
Snowmotion
Postby Snowmotion » Sun Sep 15, 2013 12:01 am
I can tell sarcasm! (I am a sucker, Dan)
What does that port do?
Postby NitroDann » Sun Sep 15, 2013 12:07 am
It's where the exhaust escapes the engine and out the exhaust pipe.
It should be perfect and smooth for good power.
On a turbo car it doesnt make so much difference but its still important, in an n/a car its very important.
Snowmotion
Postby Snowmotion » Sun Sep 15, 2013 12:18 am
Doh, not that port Dan.. I know what the exhaust does. (and realise that this header is not that good)
I was referring to the EGR port but I used search and now understand.
Now to work out the size and thread to make a join.
emily_mx5
Postby emily_mx5 » Sun Sep 15, 2013 12:37 am
just delete it man, 2 bolts and a plate on the inlet manifold, and a bolt to block the hole in the extractors.
Fra66L
Postby Fra66L » Sun Sep 15, 2013 9:15 am
emily_mx5 wrote:just delete it man, 2 bolts and a plate on the inlet manifold, and a bolt to block the hole in the extractors.
There's a nice brass fitting from the Bunnings plumbing section that fits quite nicely - the thread is subtly different but nothing that some exhaust gasket putty stuff can't fix. Been there, done that. :)
The Green Meanie - Grace Green NB8A
Veilside - It's Japanese for UGRY!
Snowmotion
Postby Snowmotion » Sun Sep 15, 2013 12:45 pm
Do you recall the size fitting?
I just got a 15mm male to male but it is too small so thinking it must be 20mm.
Fra66L
Postby Fra66L » Sun Sep 15, 2013 1:56 pm
Sorry, no I don't. Working on the other side of the Pacific at the moment so no way I can check either :(
Evil Panda
Postby Evil Panda » Mon Sep 16, 2013 8:16 pm
Wow.... they look nothing like the set I got.
My ports were nice and smooth... I took one little edge off with the Drimmel, other than that they were schmick.
I take it this is not for an NA6?
Are these a secondhand set that have been repaired?
