New Radiator for 2000 NB
Black_Penguin
Re: New Radiator for 2000 NB
Postby Black_Penguin » Fri Sep 13, 2013 12:24 am
The 42mm core all alloy Cooling Pro/ASI radiators will fit with no cutting/modification.
Where are you on the coast? I'm at Ulladulla and I have a 42mm Cooling Pro fitted.
Black_Penguin
Postby Black_Penguin » Fri Sep 13, 2013 10:39 pm
52mm will be on the big side to fit comfortably, I got my 42mm from MX5 Mania. It was $290 delivered 2 years ago.
Muzdaman
Postby Muzdaman » Fri Sep 13, 2013 10:43 pm
Email the seller. He is likely to have the smaller one as well.
de Bounce
Postby de Bounce » Sat Sep 14, 2013 8:15 am
52mm will fit fine in a NB8A, a little tight in a NB8B.
There are 42mm radiators available on ebay, do a search for
aluminum radiator Mazda Miata MX5 98-05 42mm
There are numerous threads on the ASI Aluminum radiators on here.
Vast majority have not had any issues with them
Motorkhana Video
Postby 93_Clubman » Sat Sep 14, 2013 3:51 pm
Get a 42mm ASI. Can only think of two forumites that had the faintest of leaks from their new ASI & in both cases the supplier immediately replaced the radiator without requiring return of the other one.
deviant
Postby deviant » Sat Sep 14, 2013 4:21 pm
Have used ASI and Cooling Pro 42mm radiators with no real issues. I would say the ASI was marginally easier to fit.
Do it once and forget about it. An ally radiator will last as long as the car.
