I have looked at some of the posts about radiators, but they are not much help. I need to replace mine, as it is leaking where the plastic top meets the aluminium core. There are quite a few on ebay. Some are cheap, some expensive. Some have a core of more than 16mm thickness, so I am concerned about whether they fit without lots of cutting, pushing and shoving. Some reviews suggest to steer clear of certain brands and companies.
I would really like some advice on the best radiator to fit, with a price up to about $200. I appreciate that you get what you pay for, but my local (rip-off) radiator "expert" wants $280, but would not tell me what brand the radiator would be. I would be happy with plastic/aluminium, or all aluminium. I am on South Coast NSW.
Thanks in anticipation.
New Radiator for 2000 NB
- Black_Penguin
Re: New Radiator for 2000 NB
The 42mm core all alloy Cooling Pro/ASI radiators will fit with no cutting/modification.
Where are you on the coast? I'm at Ulladulla and I have a 42mm Cooling Pro fitted.
Thanx Black P.
This one on ebay at the moment is 52mm @ $165.
http://www.ebay.com.au/itm/ASI-Super-Cooling-52mm-aluminum-radiator-Mazda-Miata-MX5-98-05-/261145222770?pt=AU_Car_Parts_Accessories&hash=item3ccd77de72&_uhb=1
Could you give me a lead on supplier of 42mm please. I am near Nowra.
- Black_Penguin
52mm will be on the big side to fit comfortably, I got my 42mm from MX5 Mania. It was $290 delivered 2 years ago.
Email the seller. He is likely to have the smaller one as well.
- de Bounce
52mm will fit fine in a NB8A, a little tight in a NB8B.
There are 42mm radiators available on ebay, do a search for
aluminum radiator Mazda Miata MX5 98-05 42mm
There are numerous threads on the ASI Aluminum radiators on here.
Vast majority have not had any issues with them
Get a 42mm ASI. Can only think of two forumites that had the faintest of leaks from their new ASI & in both cases the supplier immediately replaced the radiator without requiring return of the other one.
Have used ASI and Cooling Pro 42mm radiators with no real issues. I would say the ASI was marginally easier to fit.
Do it once and forget about it. An ally radiator will last as long as the car.
Users browsing this forum: No registered users and 125 guests
