Although these are consistant, are they a bit low?
Thanks Nicky
emily_mx5 wrote:should be more around 170 - 190
did you have throttle 100% open?
crank over till gauge didnt climb any further?
hks_kansei wrote:emily_mx5 wrote:should be more around 170 - 190
I seem to recall 180 being the norm, so the range above sounds about right.
When the engine was turbo'd you didn't do anything like lower the compression etc? (thicker head gasket etc?)
The other option is, it's not an engine from an Automatic NA is it? I seem to recall the auto ones had less lift on the cams, and I think from memory also had lower compression ratios than the manuals.
NitroDann wrote:Arent you a mechanic?
Anyways, The test needs to be done with a very healthy battery or jumper cables hooked up and full throttle.
NitroDann wrote:Get another car hooked up to it and running just as if you were jump starting it.
sticky nicky wrote:I had a compression test today and they came in at 140, 143, 140 and 143.
sticky nicky wrote:Just had my replacement engine (1.6, long nose crankshaft) tested for compression before it goes in. Results were 225, 225, 225, 175.
NitroDann wrote:Of course, come on, do the math.
