NC rear view mirror
cwto24
NC rear view mirror
Postby cwto24 » Mon Aug 26, 2013 8:27 pm
So i'm stumped. NC MX-5 parts in Japan seem to have a different part number (well for the rear view mirror at least).
Some odd reason my rear view mirror is cracked which i noticed after purchasing the car.
I've been looking at this for a while
http://www.nengun.com/auction/item/s348097635
Thing is that the part that they specify is "IE4 022197" or "IE4 012197" which isn't a match to the 06 NC i have. That part number is IE8 011681.
Anyone care to shed some light if this will be a direct fit for the 06 NC or if i should keep on looking?
Regie wrote:spending my money again Trevor :D
Re: NC rear view mirror
Postby Regie » Tue Aug 27, 2013 8:46 am
they have the self dimming mirrors as an option overseas on the NC, so there are a few variants around
Charlie Brown
Postby Charlie Brown » Tue Aug 27, 2013 10:53 am
Why not pick one up second hand? Way cheaper.
JayMo
Postby JayMo » Sat Sep 07, 2013 10:58 pm
Has any one installed one of these self dimming mirrors? Ie is it just send 12v up there and earth?(ie self contained) or is it a module controlled device.
The flip thing is a PITA in a convertible at dawn and dusk.
NC1, Black & Tan, Cow & Canvas
Mazda3 SP25GT, Soul Red Metallic
TieNN89
Postby TieNN89 » Sun Sep 08, 2013 1:53 pm
JayMo wrote:Has any one installed one of these self dimming mirrors? Ie is it just send 12v up there and earth?(ie self contained) or is it a module controlled device.
Self dimming mirrors have sensors on the front and rear of the mirror
Basically it detects if the light is brighter from the back than the front then it will dim
Postby Regie » Sun Sep 08, 2013 6:04 pm
I have been thinking the same thing myself
It looks like it was an option on the MX5 in the states, might be able to find one over there
TieNN89
Postby TieNN89 » Mon Sep 09, 2013 12:52 am
I believe they were an accessory for NC2+ in the states.
You don't need to buy one that came for the MX-5 because the NC isn't pre-wired with the wires you require anyway so you still need to run wires down to the fuse box for the mirror
So that opens up your options but you need to make sure it's within reason and you can still use the visors because these mirrors are bigger oh and the mount
JayMo
Postby JayMo » Wed Sep 11, 2013 9:26 pm
Thanks, having come out of B7 V6 Passat where everything is canbus or module controlled , I was checking... don't know what to do with myself now I have nothing to reprogram via VCDS... :( (In the Passat the center mirror dims the door mirror as well, it is module controlled and everything throws a code)
I spose now is not the time of year the sun is in the flip zone... it can wait.
TieNN89
Postby TieNN89 » Wed Sep 11, 2013 11:18 pm
Ah
It's a completely replacement mirror and requires running wires etc etc
The downside of self dimming mirrors is when you have direct sunlight from the back it doesn't dim.
If you have the stock mirror you could flick the mirror into night mode and might stop that sun shining in your eyes.
Users browsing this forum: No registered users and 108 guests
