Gear Grinding sound on Downshift into 2nd
- angusis2fast4u
This has started happening pretty suddenly just now but whenever i go to downshift into 2nd from 3rd it makes a sound like two gears grinding . This scares me because i had a new Exedy sports tuff clutch installed about 1,500km's ago.
I had a look around some people are saying put new oil in and others are saying it could be a synchro since it's only on the 1 gear. I don't want to take it back to this mechanic if its not needed because well at the moment this is annoying me because it's a brand new clutch.
What is happening to my gearbox and how do i fix it!?
*EDIT - clutch installed at 153K kms and is on about 154.8k now
~Angus
2001 Silver NB8B
Past: Grey 1990 Eunos Roadster
2001 Silver NB8B
Re: Gear Grinding sound on Downshift into 2nd
Start by making sure the clutch hydraulics are working correctly.
- angusis2fast4u
NitroDann wrote:Start by making sure the clutch hydraulics are working correctly.
DIY or best take it to mechanic?
~Angus
2001 Silver NB8B
2001 Silver NB8B
- Vehicle: 10AE
Does it do it if you double clutch?
If not, probably synchro.
Especially since 2nd gear usually cops the worst from people thinking "I are teh racecar drivar, I ken shift geers in .25 seconds!"
- angusis2fast4u
hks_kansei wrote:Does it do it if you double clutch?
~Angus
2001 Silver NB8B
2001 Silver NB8B
angusis2fast4u wrote:hks_kansei wrote:Does it do it if you double clutch?
Not sure why you are rolly eyes....He speaks the truth.
Check the clutch hydraulics are working.
Change the gearbox oil. Many threads exist on this.
- angusis2fast4u
deviant wrote:angusis2fast4u wrote:hks_kansei wrote:Does it do it if you double clutch?
It was the only smiley that says "im guilty of that"
Yeah im going to check trans oil and and search how to check hydralics, clutch feels fine and im guessing its just the synchros since all of that was just apart for the new clutch
~Angus
2001 Silver NB8B
2001 Silver NB8B
Synchromesh allows downchanges (and upchanges) when the engine speed and the road speed do not match.
It basically helps the gears to mesh correctly rather than grinding each other until they mesh.
Double clutching is where you downchange and rev match to remove the need for the synchro to do anything.
Therefore, if the 3-2 shift crunches normally, but doesn't when doible clutched, it's possibly a synchro.
If it crunches no matter what, it's probably something else.
Check the easiest things first, master cylinder, slave, fluid, bleed.
Then check the gearbox has the correct amount of oil in it (or change it if it's due)
All of that wasnt just apart to change the clutch.
Check the hydraulics.
NitroDann wrote:All of that wasnt just apart to change the clutch.
Not suggesting it was, but depending on the car's previous owners etc it's possibly had 150,000km of people sledgehammer shifting into second every day.
Maybe I'm just getting pedantic about hard shifting since I've been driving a column shifted manual the past few days.
I was replying to angus, you ninja'd me.
Ah, fair enough then.
Users browsing this forum: Bing [Bot] and 5 guests
