Throttle body sensor need help
- tescoking
Hey guys, can anyone tell me what sensor is it at the bottom of the throttle body? I believe mine has been broken, my mechanic adjusted the side of the sensor a bit for me so that my car can start in cold weather and will not stall. What is this sensor call? Is there any where I can find it, buy it, and replace it?
Re: Throttle body sensor need help
Idle speed control valve
They often work poorly due to being really dirty or corroded.
Take it apart and clean it using carby/maf cleaner.
You can't really "adjust" the iscv afaik so maybe he fiddled with the tps?
Have you ever adjusted the base idle? (Sorry not sure about it on NB's)
- tescoking
emily_mx5 wrote:They often work poorly due to being really dirty or corroded.
You could adjust it on the left hand side, there is a small hole, we used a screw driver to give it a quarter turn, and the rev is set about 1500r/min, so it won't stall when I start.
- tescoking
Is there any way I could get a brand new one?
http://forum.miata.net/vb/showthread.php?t=71119
call mazda dealer, and i reckon its gonna be like $974.46 or something equally ridiculously expensive.
- Vehicle: Non MX-5
ebay, wreckers etc have heaps. mazda 323s and ford lasers 96-98 use the same throttle body setup, so another option to look at.
it is a pretty common problem. lots of info on it if you search and use the term 'iac' or 'idle air control'.
- tescoking
project.r.racing wrote:ebay, wreckers etc have heaps. mazda 323s and ford lasers 96-98 use the same throttle body setup, so another option to look at.
Thanks man, I will look it up now.
