Cheap ebay 'Empire Performance' extractors anyone?
- 16bit
Re: Cheap ebay 'Empire Performance' extractors anyone?
my experience with ebay extractors is pipe thickness is not enough and they are almost never flat.
- bootz
What do you mean by 'flat' How can a header be 'flat'
It has 2 flanges, both of which need to be flat, the head flange is warped often.
- bootz
NitroDann wrote:It has 2 flanges, both of which need to be flat, the head flange is warped often.
Yeah, I could see how that would be a bitch.
I would give them a try, price is right, but the gain on a NB8B would be insignificant.
- 16bit
what dann said.
- Vehicle: NC - LE
Turned up today....seem to look like any other header unit i have seen...will post pics and get a vid of before and after noise.
- Learner Driver
Could you measure the outer and inner diameters of the runners just for comparisons sake?
My set also turned up yesterday. I have not had a good look at it yet but I was pleased to see they supplied 2 gaskets and bolts which was not mentioned on the ebay listing.
Looking at the position on the o2 sensor I am presuming I will need to lengthen the o2 sensor wire.
- Vehicle: NC - LE
Yes you will need to lengthen as the o2 bung seems to be further down. I was going to replace mine anyway as i am unsure if it has ever been done.
- Evil Panda
200 dollars for 'no noticeable change'..?
- Evil Panda
NitroDann wrote:200 dollars for 'no noticeable change'..?
I had a cracked weld on the old rusted unit, so figured $169 wasn't too bad as I plan to turbo down the track and it will have a short life in the car.
I wasn't expecting anything impressive at that price point.
Mind you, I've only dríven it to work a couple times. Which is literally 3 blocks away.
I'll take it out on the weekend and give it a real trial.
Its a shame they didnt make any more power on your setup, Id have given you a stock set
- Evil Panda
I've been watching your build on FB.
I'll probably be in touch when it's turbo time.
- Vehicle: NC - LE
How did you go with the o2 sensor...any dramas?
Users browsing this forum: No registered users and 126 guests
