Cheap ebay 'Empire Performance' extractors anyone?
16bit
Vehicle: NB8A - Supercharged
Re: Cheap ebay 'Empire Performance' extractors anyone?
Postby 16bit » Fri Aug 16, 2013 9:01 pm
my experience with ebay extractors is pipe thickness is not enough and they are almost never flat.
bootz
Postby bootz » Fri Aug 16, 2013 10:18 pm
What do you mean by 'flat' How can a header be 'flat' :?:
Postby NitroDann » Fri Aug 16, 2013 10:23 pm
It has 2 flanges, both of which need to be flat, the head flange is warped often.
bootz
Postby bootz » Fri Aug 16, 2013 11:04 pm
NitroDann wrote:It has 2 flanges, both of which need to be flat, the head flange is warped often.
Yeah, I could see how that would be a bitch.
I would give them a try, price is right, but the gain on a NB8B would be insignificant. :(
16bit
Postby 16bit » Fri Aug 16, 2013 11:32 pm
what dann said.
mazdaz
Vehicle: NC - LE
Postby mazdaz » Mon Aug 19, 2013 11:19 pm
Turned up today....seem to look like any other header unit i have seen...will post pics and get a vid of before and after noise.
tiggsh
Postby tiggsh » Tue Aug 20, 2013 8:14 am
Could you measure the outer and inner diameters of the runners just for comparisons sake?
Snowmotion
Postby Snowmotion » Tue Aug 20, 2013 9:58 am
My set also turned up yesterday. I have not had a good look at it yet but I was pleased to see they supplied 2 gaskets and bolts which was not mentioned on the ebay listing.
Looking at the position on the o2 sensor I am presuming I will need to lengthen the o2 sensor wire.
mazdaz
Vehicle: NC - LE
Postby mazdaz » Tue Aug 20, 2013 2:06 pm
Yes you will need to lengthen as the o2 bung seems to be further down. I was going to replace mine anyway as i am unsure if it has ever been done.
Evil Panda
Postby Evil Panda » Thu Aug 22, 2013 4:56 pm
Put a set of these on over the weekend just to try them out.
No noticeable change except for a little more volume above 4000rpm.
I'll see what happens when my cat and exhaust arrive.
Flanges were fine. Checked them with the straight edge before install... all good.
6 days in and no issues.
Postby NitroDann » Thu Aug 22, 2013 5:05 pm
200 dollars for 'no noticeable change'..?
Evil Panda
Postby Evil Panda » Thu Aug 22, 2013 5:10 pm
NitroDann wrote:200 dollars for 'no noticeable change'..?
I had a cracked weld on the old rusted unit, so figured $169 wasn't too bad as I plan to turbo down the track and it will have a short life in the car.
I wasn't expecting anything impressive at that price point. :wink:
Mind you, I've only dríven it to work a couple times. Which is literally 3 blocks away.
I'll take it out on the weekend and give it a real trial.
Postby NitroDann » Thu Aug 22, 2013 5:18 pm
Its a shame they didnt make any more power on your setup, Id have given you a stock set :)
Evil Panda
Postby Evil Panda » Thu Aug 22, 2013 5:24 pm
I've been watching your build on FB.
I'll probably be in touch when it's turbo time. :wink:
mazdaz
Vehicle: NC - LE
Postby mazdaz » Thu Aug 22, 2013 10:28 pm
How did you go with the o2 sensor...any dramas?
