Megasquirt owners thread
slug_dub
Re: Megasquirt owners thread
Postby slug_dub » Thu Aug 15, 2013 5:28 pm
MS'ers... I am looking to get going with one myself.
I am going to put an NB8B motor with VVT in the NA8, does that mean I should get a '94-'95 MSPNP (car is Aus '93 1.8 ), VVT Tuner, IAT sensor, Wideband and gogogo? Am I missing anything?
Locutus
Postby Locutus » Thu Aug 15, 2013 10:35 pm
MS3 + MS3X gives you the latest and greatest with built in VVT control. Less to build, more inputs & outputs than you can poke a stick at.
AFAIK the only advantages of buying MS2 are cost and ability to hack the firmware (MS3 is not open source).
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Thu Sep 19, 2013 10:44 am
does the ms2v3 tune and run off the wideband or do I need the narrowband too?
Postby NitroDann » Thu Sep 19, 2013 10:56 am
WB only is fine, it also autotunes but you still have to tune spark manually and watch the AFRs to make sure it never goes lean.
16bit
Postby 16bit » Thu Sep 19, 2013 11:09 am
sweet, didn't want to have to get another bung if i didn't need to.
gslender
Postby gslender » Thu Sep 19, 2013 6:57 pm
16bit wrote:sweet, didn't want to have to get another bung if i didn't need to.
If you buy an innovate LC1 (which has two signal outputs) you can have 1 of them set to wideband for the standalone ms2/ms3 ecu or gauge, and the other set to narrowband (emulated) so that you can run the stock computer again without having to swap out the wideband o2 sensor and controller.
sailaholic
Postby sailaholic » Fri Sep 20, 2013 7:38 am
I thought lc1 was discontinued?
gslender
Postby gslender » Fri Sep 20, 2013 11:14 am
sailaholic wrote:I thought lc1 was discontinued?
Correct. The LC2 replaces the LC1 and is essentially the same, but some places are still providing the LC1 at good prices, but yeah if you can't get the LC1 then the LC2 is now the way to go.
G
16bit
Postby 16bit » Tue Sep 24, 2013 1:51 pm
i have an lc1 now so that sounds optimal.
thanks everyone.
Postby NitroDann » Tue Sep 24, 2013 2:14 pm
Just street tuned another on this morning.
From rough start and idle poor AFR's and no throttle response to gorgeous in an hour :)
PnP FTW!
Postby NitroDann » Tue Sep 24, 2013 9:07 pm
Hey my MS updated, so I re-entered my full version code...
Where the hell is idle speed target map now?
And startup idle duty cycle?
Not much fun tuning idle with a screwdriver..? Was totally fine this morning, update.. now I cannot find idle map?
Postby NitroDann » Tue Sep 24, 2013 9:18 pm
Basemap was simply set to warmup only. So the target curve wasn't bold, it was greyed out (the option box) All good now.
Angryoven
Vehicle: NA6 - Turbo
Postby Angryoven » Thu Oct 03, 2013 8:41 pm
Hey Guys,
Been running my turbo mx5 on MS3 for awhile now seems pretty solid but want to get some more power out of it. Anyone recommend some dyno places in Sydney willing to touch a MS3?
Nick.
Postby NitroDann » Thu Oct 03, 2013 9:11 pm
Pm me. I don't want to openly advertise the shop and piss the guys off.
sabretooth
Postby sabretooth » Sat Oct 05, 2013 8:54 pm
Hey gslender, do you sell MS3 bits and pieces?
Users browsing this forum: No registered users and 124 guests
