Chirp coming from intake
PT
Postby PT » Sat Aug 10, 2013 6:10 pm
Hi all,
I picked myself up a Auto Exe Carbon Fibre Ram Air intake for my NB8B, fitted it up all good.
Problem I'm having is as you get on the throttle, the intake lets out a loud chirp. I removed the intake looking for air leaks and tried it with just a pod filter I had here.... Same chirp.... Tried it with no filter, just the 90deg bend from the throttle body with the MAF attached, same chirp.
Is it a normal MX5 thing or is it my MAF?
Thanks
Paul
Past:
2005 Mazda MX-5 SE
1991 Mazda MX-5 NA6
Re: Chirp coming from intake
Postby NitroDann » Sat Aug 10, 2013 6:12 pm
Something isnt quite right.
Any video or audio.. pictures?
Apu
Postby Apu » Sat Aug 10, 2013 6:13 pm
I have the same thing on my Integra...so would be keen to hear what's causing it on yours.
PT
Postby PT » Sat Aug 10, 2013 6:16 pm
Will grab a video of it tomorrow. Only lasts a half a second. Happens if you open the throttle suddenly, not if opened slowly.
Past:
2005 Mazda MX-5 SE
1991 Mazda MX-5 NA6
slug_dub
Postby slug_dub » Sat Aug 10, 2013 6:38 pm
Its not a belt is it?
PT
Postby PT » Sat Aug 10, 2013 6:42 pm
No, definately a wind noise.
Past:
2005 Mazda MX-5 SE
1991 Mazda MX-5 NA6
stb
Postby stb » Sat Aug 10, 2013 7:17 pm
I've got the same thing on my NA8, it only started after removing the airflow meter. My current theory is it is something to do with the idle control valve and the removal of the AFM made the flow path clear enough to hear it - but I haven't spent a lot of time investigating.
stb
I've got the NB8B motor in an NA8.
Postby Okibi » Sat Aug 10, 2013 11:53 pm
Check the hose running from the cam cover to the intake, could it be sucking in any air though there?
Any photos of the engine bay?
project.r.racing
Postby project.r.racing » Sun Aug 11, 2013 9:21 am
it's normal to get these kind noises when you open up the intake system. whistles and thuds from the IAC openning and closing. rushing water noises from air rushing past near closed butterflys etc. if the noise ain't there with the stock airbox and intake/resisnator attacked, then it is fine.
PT
Postby PT » Sun Aug 11, 2013 10:20 am
No problem with the noose between the rocker cover and the intake, intact and sealed well.
It does the noise with no filter and just the MAF connected to the pipe.
Well try and get a video off it today, what's the easiest way of publishing that? Youtube?
Past:
2005 Mazda MX-5 SE
1991 Mazda MX-5 NA6
slug_dub
Postby slug_dub » Sun Aug 11, 2013 10:34 am
Yep definitely YouTube :)
Postby 93_Clubman » Sun Aug 11, 2013 11:52 am
IAC +1
PT
Postby PT » Sun Aug 11, 2013 12:47 pm
I'm thinking you could be right. Might try adjusting it slightly. From memory don't you need to bridge two points points in the diagnostics port to adjust it correctly?
Past:
2005 Mazda MX-5 SE
1991 Mazda MX-5 NA6
Postby Okibi » Sun Aug 11, 2013 5:54 pm
Could you disconnect the EGR to test without any consequences? Does anyone know if the EGR is closed by default? You might need to reset an error code.
