I have an nc2 in the 6sp AT and have found an nc1 for a donor, has anyone done this? or know what needs to be done to make this work?
Assuming that I could get the parts, what would be required?
thanks,
Matt
NC Manual conversion
Re: NC Manual conversion
probably...
Gearbox, clutch, flywheel, clutch lines and cylinder and pedals.
Ecu, wiring harness, TPS
Centre console and stick etc
Dashboard instruments.
Thats probably close to it.
I suspect it would be a better financial proposition to sell yours and buy a manual
- Vehicle: Non MX-5
and alot of headache pills. the electrics like the can-bus in these things means you have to swap over almost all the electrics from the donor car to make if work. and i'm not talking just the engine and gearbox electrics. things like the power steering, climate control etc all all intergrated.
This is a duplicate thread. Can the mods delete it?
