mrpham's summer build
Re: mrpham's summer build
Congrats!!!
SUPER LOUD
HEADPHONE WARNING !
Good but.
HEADPHONE WARNING !
Good but.
- Dweezle
Hells yeah! !
Sent from my GT-I9100T using Tapatalk 4
ALL MUSCLE CARS ARE CRAP
Jeremy Clarkson
Jeremy Clarkson
- mrpham
So stoked about today's progress! Had issues yesterday but everything was all sorted this morning.
I'm very surprised how easy it was to get the engine started and idleing. I figured with the cams I have, ITBs, lightened flywheel, and useless basemap, we would have issues with getting it to idle. It idles around 1000RPM when warm, cold start it sits around 600rpm although very rough.
Current Forum Specials!
Congrats, love the sound!
- slug_dub
Brilliant mate!
- Gladiator
OOOHHH, AAAHHH, AAAAAHHHHH, AAAAAAAAAAAHHHHHHH.
- Vehicle: NA6 - Turbo
- gslender
mrpham wrote:So stoked about today's progress! Had issues yesterday but everything was all sorted this morning.
So what was the resolution to all the problems?
G
- mrpham
The fuel pump was having issues because I wired my relay incorrectly. It was wired for a ground trigger from the ECU, and the DIYPNP outputs 12V trigger. So picked up a new transistor from RS Components for 35cents and rewired the relay.
It wasn't registering cam/crank signals because I installed some resistors in the DIYPNP that didn't need to be there. There only used for VR type sensors.
And TPS was fluctuating because my MTX-L was grounded with the ECU. It created noise but gave identical AFR values as Tuner Studio, so I grounded it elsewhere and solved the TPS issues but now my AFR values don't match.
Sweet, but thats why the LC1 and guage combo is recommended.
- mrpham
NitroDann wrote:Sweet, but thats why the LC1 and guage combo is recommended.
Was thinking about adjusting the wideband curve in Tuner Studio, do you think that could do it?
Yeah just eyeball it.
- A.Chen89
- Vehicle: NB8B - Turbo
Just out of curiosity are you using the voltage output or the serial off the mtx-l? Did you end up grounding it off the motor?
Users browsing this forum: No registered users and 81 guests
