Hi all,
Im currently trying to get my NA Mx5 reregistered here in wa so that I can drive to race meets without the need for a trailer/ tow. The only problem in having is the drivers side frame rail looks like its taken a kerb and has been squashed up, safe to say its not going to be perfectly square again any time soon... from what I understand the frame rails dont really have anything to do with the chassis integrity but im guessing if I try go for road worthy ill be told the chassis is bent and fail? Any have any experience with this or with repairs with these? Any help is appreciated and I will post sone pics later when I get a pc.
squashed frame rail repair
- Vehicle: ND - Turbo
Re: squashed frame rail repair
Tap it as good as you can with a hammer and some wood, then give it a touch of bog and some under body deadener and flick dust at it if needed so it looks un touched -ish.
GHETTOCET
Lump hammer and a pull hammer
between those two tools you should be able to pull them fairly straight (pull hammer more so)
You can also take a small (about 3") bench vice off the bench and use it to squeeze the rails back out most of the way towards square.
Cheers guys,
Got a lump and slide hammer so will try that. Get it mostly square and then make it good with the vice, its pretty stuffed for a good 400mm.... will let u know how I go
- lightyear
- Infinity & Beyond
- Vehicle: NA6 - Turbo
The best way is to grind it clean, tack weld a 50mm or so piece of scrap steel onto the edge of the rail. Pull it down with a slide hammer. And repeat till it is all pulled out.Then tap it a bit till it looks ok.
