mrpham's summer build
Re: mrpham's summer build
With my jenveys, I have a vacuum block with the following,
1 line to the map sensor for the ecu with a T to the vac gauge,
1 line to the brake booster using the original hose because of the 1 way valve in it
4 lines to the throttle bodies, 1 per body of EQUAL LENGTH.
The reading from the big forums and other places suggest that 4 lines of EQUAL LENGTH ensures a nice stable vaccume for the map sensor and ecu to read. It also helps the brake booster keep enough vaccume on tap when you are doing the stop start thing in traffic. This is the setup I have been using for near 12 months now on my daily and I've had no issues at all.
Based on the photos and workmanship I've seen here, knocking up a vac block and making all the lines look pretty and neat should be child's play for you :-D
Ben
Ben
- mrpham
Thanks Ben!
I was thinking about the equal length tubing, will keep that in mind.
Current Forum Specials!
Let me know when I'll try and come over
- corners
- Vehicle: ND - Supercharged
mrpham wrote:Magpie wrote:When is the first start?
Hey Mark, I'm hoping I'll get it started next week. Only the fuel hoses and vacuum lines to sort out now. Fuel stuff is all planned out but still not sure how to do my vacuum lines. Might just do something rough for now to get the car started and properly sort it out later.
There needs be a group meeting when this thing is first cranked and started
- mrpham
corners wrote:There needs be a group meeting when this thing is first cranked and started
Swing by whenever dude!
sailaholic wrote:Let me know when I'll try and come over
You back in Aus?
Started a bit of the fuel stuff today, will go into detail tomorrow.
Yeah got back Monday. Your car must be close because Shane and I are a ways of. Rule of itb 5s in QLD. Anymore then 1 running at a time results in a warp in the time space continuum.
- Gladiator
sailaholic wrote:Yeah got back Monday. Your car must be close because Shane and I are a ways of. Rule of itb 5s in QLD. Anymore then 1 running at a time results in a warp in the time space continuum.
As long as the flux capacitor is working you should be right.
Mine maybe running soon as well but not before the next club track day:(
- mrpham
ITB Build Part 16 - http://omgpham.com/itb-build-part-16
More progress today!
Picked up all my Aeroflow fuel fittings from Race Car Engineering. Fittings are all push lock style, black and -6AN size. Thanks to the guys at Auto Xperts for advice and supplying the hose, looks OEM and I prefer it over the black braided stuff I bought earlier.
For extra security hose clamps were also used.
Hoses completed and installed!
Fookin' awesome install!
Slightly NSFW, scroll down with care
See this chicks face, thats how I feel looking at the latest pics with the engine in the car.
- corners
- timk
- mrpham
Got her running thanks to a few mate's giving me a hand.
It's yet to be tuned, just got it started and idling at a reasonable AFR. Have to look into stiffer engine mounts too.
Install work looks mint, great to hear you got it working as well. Putting my engine bay to shame!
Might have to come look at your views adjuster install as it looks like I have to pull my booster out for a reco.
Users browsing this forum: No registered users and 55 guests
