Misfiring? Solutions
Re: Misfiring? Solutions
Postby 93_Clubman » Wed Jul 31, 2013 5:06 pm
Yeah, behind drivers seat (RHD) under the car.
Not saying this is causing the issue, just letting you know there are better priced alternatives.
Roadrunner
coyotes after you
Postby Roadrunner » Wed Aug 07, 2013 3:17 pm
How did you go with rectifying this?
Was it the o2 sensor in the end? (and did it throw any error codes?)
Im having a similar issue.
MeepMeep
Forshaw
Postby Forshaw » Thu Aug 08, 2013 12:50 am
So basically I was looking in the right area, it was obvious it wasn't running on all 4 cyl.
Starting from of course checking connections to then replacing spark plugs.. No permanent fix, then to leads.. Paid retail for sadly, but I needed the car to get to and from work, and that had fixed the issue, the reason it was running rich was because of the faulty leads.
I'd suggest finding someone with working leads and seeing if the issue persists
Form is within the function.
Users browsing this forum: No registered users and 124 guests
