There's been a bit more progress over the past few days.
The first item on the critical path was to position the engine in such a way that there's good clearance to all important engine externals whilst keeping it reasonably low, but not compromising the front aero package.
The front cover in position.
Some jewellery in the form of an integrated dry sump and pump assembly, and a side mount alternator arrangement.
With the engine in the desired position, the subframe was offered and notched accordingly.
Due to the extra length of the engine the factory steering rack is not useable. I've acquired a custom powered quick rack to work with the longer engine.
So the next job is to mount it without adversely affecting the steering functionality (ie. bump steer, Ackermann etc...).
