Hi guys,
I just wondering which silicone sealant should I use
to seal head(cam cover) gasket. I was using this http://www.supercheapauto.com.au/online ... ab-Reviews before,
But I found it is too hard and brittle. I want something flexible that
can seal the gasket properly.
cheers
Silicone sealant for head gasket suggestion?
- mx5lover
Re: Silicone sealant for head gasket suggestion?
Rtv. And its definately not the head gasket.
- davekmoore
That was very gentle Dann.
- mx5lover
NitroDann wrote:Rtv. And its definately not the head gasket.
oops, wrong link, that item is I use for fixed rainrail crack.
this is the one I used before http://www.supercheapauto.com.au/online ... 0701#Cross for gasket.
Any recommend product, Dann?
Go to SupaRepcoBarn and ask for RTV.
You only need a few dabs of RTV at the specified points.
- mx5lover
NitroDann wrote:Go to SupaRepcoBarn and ask for RTV.
thanks Dann, will get it tomorrow morning
manga_blue wrote:You only need a few dabs of RTV at the specified points.
Thanks Manga_blue, I have done once before and know where to apply the RTV
