These popped up on the Goodwin site.
Looks like a good thing for early models to prevent that sway bar mount failure
http://www.good-win-racing.com/Mazda-Pe ... urce=News1
Sway bar mount braces
Rob
Re: Sway bar mount braces
I saw these in my email this morning to
I always knew that the sway bar mounts flexed somewhat but it is still fascinating to see by how much. I would love to know how this affects roll rates and stiffness.
I am guessing that these blocks are just forced against the chassis rail and the white cross brace is to stop them twisting sideways and out of place?
Looking at the flex without the brace, I'd guess a softer bar could be used once the brace is installed.
Rob
I have had one of these braces for a few years after buying them off Lou, the brace didnt fit on the SE but I kept those hunks of metal and long bolts. They can be a bit of a PITA to install but i'd recommend them.
- zorak
wow never knew there was so much flex under there either
better get under the car to see that my chassis mounts haven't already cracked
NB8A
WP 1:10.69
SMSP (south) 1:04.41
SMSP (GP) 1:53.98
WP 1:10.69
SMSP (GP) 1:53.98
Other sway bar mounts (at the bottom of the page) http://www.iscracing.net/miatasuspension.html
Okibi wrote:I have had one of these braces for a few years after buying them off Lou, the brace didnt fit on the SE but I kept those hunks of metal and long bolts. They can be a bit of a PITA to install but i'd recommend them.
You sure they won't fit?
I have a set on my car (see http://mx5cartalk.com/forum/viewtopic.php?f=57&t=41091&hilit=sway+bar&start=26) and so does MINX.
For those wondering why these are useful, see http://mx5cartalk.com/forum/viewtopic.php?f=30&t=51957&p=653170&hilit=yeah#p653170
Lokiel wrote:..You sure they won't fit?..
These fit
http://www.racingbeat.com/Miata-1990-2005/Sway-Bars/54123.html
But I didnt fit this
http://www.racingbeat.com/Miata-1990-2005/Sway-Bars/54121.html
Can't remember if the pipes got in the way or I thought it wouldn't fit when I put in a larger radiator.
Ah, makes sense now - when I bought mine, Brian just recommended the first one.
Users browsing this forum: No registered users and 353 guests
