A BOV can be fitted at any time in about 10 minutes and it saves remaking the this section. This costs the same in material as doing it the easy way, but builds an upgrade path into this side of the system.
OurCognitiveSurplus wrote:Are these images dead for anyone else, or just me?
fastfreddygassit wrote:Nice work so far.![]()
Are you going to get both the manifold faces machined/skimmed or will they be ok for this build?
NitroDann wrote:....The reason Ive ported this wastegate is because the turbo is quite small, even for a 1.6L, the wastegate might have trouble flowing enough gas to bypass the turbine wheel enough for good boost control and as a result boost may rise with rpm as the wastegate has a harder and harder time bypassing gas for boost control..
