Time for engine to warm to operating temp?
tooch
Postby tooch » Mon Jul 08, 2013 12:09 pm
Just wondering how long on average an NA8 should take to get up to operating temperature (on the gauge)?
Mine seems to take close to 10 mins of driving before the heater puts out any noticeable heat, something that's made for some painful mornings lately when starting work at 5am!
I think I'll change the thermostat and see if that helps, unless 5-10 mins is normal?
timk
Re: Time for engine to warm to operating temp?
Postby timk » Mon Jul 08, 2013 12:16 pm
My coolant temp takes a few minutes, then oil takes a good 5 minutes longer. I'll take a look next time I start the car to redefine 'a few minutes' a bit more accurately.
CQYD
Postby CQYD » Mon Jul 08, 2013 12:59 pm
4-5 kms of driving or about 5 mins, This is with a 52mm radiator and 15 degrees is about as cold as it gets here.
Caffeine
Postby Caffeine » Tue Jul 09, 2013 12:01 pm
My car is up to it's operating temperature in the time it takes me to drive out from the 3rd level underground carapark at work, so approximately 5 minutes.
I had a stuck thermostat a while back, and the car would take around 10 to 15 minutes to warm up properly, and the temperature gauge would drop to cold on long hill descents.
I have a large aluminium PWR radiator.
Postby manga_blue » Tue Jul 09, 2013 1:48 pm
It wouldn't matter if you had a radiator out of a Mack truck. The thermostat is meant to stay shut and not let water through to the radiator until the engine is up to normal temps. 10 minutes is too long. Either the thermostat is opening too early or not shutting properly or your temp gauge is reading wrong. I'd take the thermostat out and, if it looks OK, test it by bringing to boil in a saucepan with a thermometer in it. It should start to open in the 80s. If it looks crusty or is not fully shut when cold or fails the saucepan test then replace it.
tooch
Postby tooch » Wed Jul 10, 2013 2:01 pm
Thanks guys, I'll pop the thermo out and have a look at it. Might just replace it anyway while I've got it all apart.
MattR
Postby MattR » Thu Jul 11, 2013 9:19 am
If you are replacing the thermostat, test the new one as described above before fitting. It's not uncommon to get a dud one from the box.
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Fri Jul 12, 2013 11:30 am
if you want it to heat up quicker do a coolant re route.
Aussie Stig
Stig
Postby Aussie Stig » Fri Jul 12, 2013 4:00 pm
Does anyone know, offhand, whether we can use the Ford Laser or Mazda 323 thermostat?
sailaholic
Postby sailaholic » Fri Jul 12, 2013 6:58 pm
Assuming your talking about the bp or b6 engine versions, probably.
Check what their temps are, all model mx5 actually changed the thermostat slightly. Have a look on the Mahura website for photos and temperatures.
slimx
Postby slimx » Thu Jul 25, 2013 10:08 pm
Temperature conditions can make a big difference, in WINTER i was unsure if the fan was working lol. In Summer it kicked in after 5 minutes.
Postby Okibi » Thu Jul 25, 2013 11:32 pm
My NB took about 4-5 mins before the thermostat would open
Users browsing this forum: No registered users and 117 guests
