NB fog light switch bulb replacement.
green_comet
Car Detailing Guru
Postby green_comet » Sun Jul 07, 2013 12:37 am
Hey guys,
The fog light switch in the SP has stopped illuminating when the fogs are on, I pulled the switch apart and it appears the tiny bulb inside has burnt out.
I'm just wondering if anyone knows the part number for this bulb?
Re: NB fog light switch bulb replacement.
Postby hks_kansei » Sun Jul 07, 2013 12:54 am
Does it come out of the plastic bit?
I was at Supercheap auto today and they had tiny wedge base bulbs that looked about the same size as that (assuming it comes out of the plastic)
I can't remember the bulb number, but they were in with the rest of the headlight/indicator bulbs
green_comet
Car Detailing Guru
Postby green_comet » Sun Jul 07, 2013 12:56 am
na, it doesn't come out, it's actually part of the bulb.
Postby hks_kansei » Sun Jul 07, 2013 1:01 am
bugger.
Not sure then, knowing Mazda it won't be available separately though :(
If it matches any bulbs from an NB cluster I have a spare cluster I'm happy to donate a bulb from.
Postby Mr Morlock » Sun Jul 07, 2013 2:50 pm
just go into Bursons - they carry a full range and should be able to identify it. Its clearly a wedge bulb but it may well be sold as an assy ie with the base bulbholder being integral. It should not be hard to source.
green_comet
Car Detailing Guru
Postby green_comet » Sun Jul 07, 2013 6:42 pm
I went to a few different car places today and all of them had never seen a bulb like it, I ended up buying a small 12v globe from Jaycar and wiring it up in the original holder.
Quick question, is the fog light switch supposed to be illuminated always while the lights are on, or only when you turn the fogs to on?
slimx
Postby slimx » Sat Jul 27, 2013 3:16 am
Only when fogs are on
