Quick Reroute flow question
Dweezle
Postby Dweezle » Fri Jul 05, 2013 3:42 pm
Hi Guys
Finishing up the install of my brothers 1.7 build.
We have a NitroDann Reroute in place and i have a small question that i would just like to confirm i am on the right track with solving.
Basically it is a cold side reroute with a Front Thermo housing and neck Delete. Welsh plug installed.
Now my issue is the Air valve has a coolant port on it that used to run to the front thermo housing neck t-piece along with another hose that ran to the outlet pipe from the water pump. I think this is called a mixing manifold?
My question is can i just connect a hose from the Mixing Manifold to the Air Valve coolant port on the intake manifold or will the flow be wrong and fighting itself?
I hope my diagram makes more sense then my typing. :oops:
What i am trying confirm is can i just do what the GREEN line is doing ??
Any help much appreciated!!!
ALL MUSCLE CARS ARE CRAP
Jeremy Clarkson
aka_juffa
Re: Quick Reroute flow question
Postby aka_juffa » Fri Jul 05, 2013 4:28 pm
Hi Mark,
I am unable to see your diagram due to work internet restrictions, however is this diagram of assistance to you?
Jeff.
Postby manga_blue » Fri Jul 05, 2013 4:30 pm
I'm not sure exactly where your green line is starting from but it looks like it's running from somewhere high on the engine to the water pump inlet, bypassing the radiator. That means most of the hot water would go from the engine straight back into the water pump without any cooling. I don't think that's what you really want to do, is it? :D
The idea of any MX5 re-route is to take most of the water from the back of the head to the radiator inlet.
Muzdaman
Postby Muzdaman » Fri Jul 05, 2013 4:35 pm
I cant see why the green line wouldn't work, it would flow in the correct direction.
My reroute has each end of your green lines blocked by just jamming a bolt in a small length of hose and using a hose clamp.
same thing as yours essentially. it also allows you to delete a fair bit of those annoying intake manifold hoses.
Postby manga_blue » Fri Jul 05, 2013 4:45 pm
Those annoying little intake manifold hoses are there to enable the idle speed control valve to work properly.
Postby NitroDann » Fri Jul 05, 2013 5:11 pm
Yes mark what you suggest is fine.
Its a fluid even a small pressure differential will promote flow and onlya little flow is needed for its warmth on that valve.
sailaholic
Postby sailaholic » Fri Jul 05, 2013 5:23 pm
Why did the valve need to be warmed?
Postby manga_blue » Fri Jul 05, 2013 5:39 pm
Wax-pellet air-valve actuator - expands with heat. For the NA6 at least.
sailaholic
Postby sailaholic » Fri Jul 05, 2013 5:44 pm
manga_blue wrote:Wax-pellet air-valve actuator - expands with heat. For the NA6 at least.
Ingesting, does it not exist on na8 or your just not sure?
plohl
Postby plohl » Fri Jul 05, 2013 5:46 pm
^not on na8
plohl
Postby manga_blue » Fri Jul 05, 2013 5:55 pm
NA8 has coolant lines to an idle speed control unit on the bottom of the throttle body assembly instead. Can't remember if it has wax pellet or electric actuator embedded in it.
Sorry about my bad on your first post Dweez, I didn't read it properly and was thinking that was your whole re-route. :oops:
emily_mx5
Postby emily_mx5 » Fri Jul 05, 2013 7:42 pm
hey mark, tell Wade that Emily told you so hahaha
Dweezle
Postby Dweezle » Fri Jul 05, 2013 10:42 pm
emily_mx5 wrote:hey mark, tell Wade that Emily told you so hahaha
HAHA What The?? :D
THANKYOU SO MUCH GUYS FOR THE HELP!!
All sorted now i think.
Of to Japan tomorrow morning but i think i have his car sorted enough for him to work on while i am gone.
Pics and vids to come.!!
Jeremy Clarkson
Users browsing this forum: No registered users and 145 guests
