broken sway bar mount, please help
mmx005
Postby mmx005 » Thu Jul 04, 2013 8:50 pm
Hi guys,
I have broken one of the studs that holds my sway bar to my chassis :-(
Is this something I can fix at home and how do I go about it?? Just bash the crap out of it till it comes or what?? Please help!!!!!! :-(
Cheers ,
Ben
Re: broken sway bar mount, please help
Postby NitroDann » Thu Jul 04, 2013 8:53 pm
Take it to a good mechanic.
TieNN89
Postby TieNN89 » Thu Jul 04, 2013 8:55 pm
What year?
Front or Rear?
Got pictures?
Steampunk
Postby Steampunk » Thu Jul 04, 2013 10:24 pm
Is it the bolt on one of the D-bush bracket?
If so, carefully drill it out and replace the bolt.
Use easy-outs if you have access to them.
mmx005
Postby mmx005 » Thu Jul 04, 2013 10:48 pm
Sorry guys, posted in a bit of a flap.
It's an nb8a, driver's side rear stud. Feels like its flat on the back. Is it a screw in type of stud or a pressed one?? I had thought about drilling it out and putting a bolt in place of the stud, but wasn't sure if it would hold/ be that simple.
yes the one that holds the D Bush in place.
timk
Postby timk » Thu Jul 04, 2013 10:56 pm
mmx005 wrote:It's an nb8a, driver's side rear stud. Feels like its flat on the back. Is it a screw in type of stud or a pressed one?? I had thought about drilling it out and putting a bolt in place of the stud, but wasn't sure if it would hold/ be that simple.
I had the same thing happen to my 89 NA, and I did exactly what you have suggested. I used Loctite on it but that was probably overkill.
A.Chen89
Postby A.Chen89 » Thu Jul 04, 2013 11:05 pm
Drill it out and replace with a nut and bolt as above. Had it happen on my last car
mmx005
Postby mmx005 » Tue Jul 09, 2013 1:47 pm
I ended up drilling my stud out last night, was relatively easy. Was quite surprised.
