Android lap timers
Sailor
Android lap timers
Postby Sailor » Fri Dec 16, 2011 6:31 pm
Looking for an android lap timer.
Been using Racechrono but switched to an android phone.
The only one I've found that looks the goods is aLapRecorder HD which is in demo mode until I buy the $6.50 upgrade.
Anyone using it?
Rob
Damo
Re: Android lap timers
Postby Damo » Sun Apr 08, 2012 4:36 pm
The ones that I've got on my phone are aLapHD, ChronoGPS, Race Ace and Trackmaster. I used ChronoGPS at the Nurburgring :) where it performed well, but I haven't had the opportunity to use the others yet. aLapHD seems to be the goods if you can mount your phone to get video, too, but probably the biggest thing with any of them from a lap timing perspective would be to use them with a 5 Hz external GPS receiver. It would be interesting to open all of them at once and simultaneously compare their respective accuracy against official timing.
Nevertheless, I'm also interested in hearing others' opinions.
NB8A (2000 Highlight Silver), KU36, Kaaz LSD, QFM A1RM, Mazda Competition engine/differential mounts, Town & Country cat-back.
plohl
Postby plohl » Sun Apr 08, 2012 7:03 pm
I have gearzy lap timer lite (FREE). I haven't used it at the track yet, just played around with it driving around. Seems pretty good, though it has crashed a few times.
plohl
Nemo
Postby Nemo » Fri Jun 15, 2012 6:33 pm
https://play.google.com/store/apps/deta ... 5vLmFwcCJd
RaceChrono is now available on Android.
Sailor
Postby Sailor » Fri Jun 15, 2012 6:58 pm
Just downloaded it.
I have a dedicated Racechrono GPS but this is great for showing my laps on my Samsung
Rob
Postby manga_blue » Fri Jun 15, 2012 10:10 pm
Nemo wrote:https://play.google.com/store/apps/details?id=com.racechrono.app&feature=search_result#?t=W251bGwsMSwxLDEsImNvbS5yYWNlY2hyb25vLmFwcCJd
Well spotted! I've been waiting for this for a year.
Hjt
Postby Hjt » Fri Jun 15, 2012 11:46 pm
Thanks Nemo, downloaded and ready to roll!
Postby manga_blue » Tue Mar 19, 2013 5:49 pm
Racechrono has just put out an update to its Android version. It's absolutely stunning. Lap review maps now show Vmins, Vmaxs and colour coded braking areas for every corner and straight by default overlaid on the satellite photo. Check it out if you've got some old session files.
Postby Jeo » Tue Mar 19, 2013 9:23 pm
It's quite cool hey.
corners
Vehicle: ND - Supercharged
Postby corners » Tue Jul 02, 2013 12:20 pm
So is Racechrono the one to use?
Eunos Roadster
Postby Eunos Roadster » Tue Jul 02, 2013 2:14 pm
Hi there,
just downloaded to my Galaxy S II. Find it hard to get started? Found Phillip Island map and is asking for New Trap? WTF :?: :roll:
Best regards
Marty
VIC MX5 Club #1912 est. 2012
1991 NA Eunos Roadster Low Budget "Racer"
1989 NA Eunos Roadster BRG Family Resto Project
Trackphotos
Postby Trackphotos » Tue Jul 02, 2013 11:24 pm
Eunos Roadster wrote:Hi there,
When you start racechrono you get the big red button 'Start', right? Press that, and it will use your location to try to find the nearest tracks to you. You can also press the 'select track manually' button and pick from either tracks youve saved as favourites, or if you press on Library at the top you can filter by country and go from there. Pick your track, and the live timer will appear after a few seconds. It will already have splits etc for the track. It is possible to make your own splits I believe, but I don't know how.
I haven't used it on track yet, will be trying it out at Lakeside in 2 weeks. It's worthless for track position/lines/corner speed if you are using internal GPS, but should give you reasonably accurate lap/split times.
beavis
Postby beavis » Wed Jul 03, 2013 4:53 pm
corners wrote:So is Racechrono the one to use?
Yes, use racechrono on an Android. Nothing on iphone is any good.
Easy to use.
Do yourself a favour, don't use your phones built in GPS, get a Qstarz 818 bluetooth GPS.
If you can't work it out, come find me in the White/Black NB8B at Phillip Island.
YanMa YatTai
Postby YanMa YatTai » Wed Jul 03, 2013 6:14 pm
beavis wrote:Yes, use racechrono on an Android. Nothing on iphone is any good.
Easy to use.
Exactly. Bought qstarz bt-q818xt from eBay, did the 5hz update and works brilliantly.
Had difficulty with auto find track but once I hit choose manually the right track shows up. Did NSW Wakefield and Marulan fine.
Sent from my HTC One X using Tapatalk 2
cwto24
Postby cwto24 » Wed Jul 03, 2013 7:57 pm
Easy to use.
Nothing on iphone is any good?
Now thats a bummer for iOs users....
Regie wrote:spending my money again Trevor :D
Return to “MX5 Motor Sport”
Users browsing this forum: Google [Bot] and 1 guest
