Black stuff to hold the plastic sheet on behind door trim
mitch_f1
Postby mitch_f1 » Mon Jul 01, 2013 9:17 am
What does everyone use to replace that hellishly sticky stuff holding the plastic sheet on to the door behind the door card that keeps the water out of the cabin please??
Apu
Re: Black stuff to hold the plastic sheet on behind door tri
Postby Apu » Mon Jul 01, 2013 9:24 am
Home made Rocky Road might do the job... :lol:
I'd clean it off and use double sided tape Mitch!
mitch_f1
Postby mitch_f1 » Mon Jul 01, 2013 9:33 am
Why yes I did make rocky road and yes it tasted amazing ;). Any particular type? I had black mastic there but it didnt stick to the plastic. Also needs to be waterproof ;)
Apu
Postby Apu » Mon Jul 01, 2013 10:18 am
We are aware there was a lot of your "love" in that Rocky Road.
I'd just use a narrow double sided tape - not quite reusable but cheap, clean and reasonably waterproof. I hate that goopy stuff.
Postby NitroDann » Mon Jul 01, 2013 11:27 am
Its common to see duct tape used when ive pulled apart used cars.
lee
Postby lee » Mon Jul 01, 2013 11:41 am
I didn't replace it when I was doing my door card bits, but for what its worth, metho is great at cleaning it up.
'91 Roadster
Postby Mr Morlock » Mon Jul 01, 2013 12:16 pm
it has been used in cars for a very long time and it does its job well.OEM use materials that are functional are not expensive. Its butyl and its quite readily available an example of a maker is Bostik - ref 5214, 5323, 5326, 5331.Check Bostik web site for more info. Its probably at Bunnings and almost certainly at auto paint suppliers.It has multi users for sealing etc. Good plan to use the right product and its useful to have.
wassup
Postby wassup » Mon Jul 01, 2013 12:18 pm
Apu wrote:Home made Rocky Road might do the job... :lol:
:lol:
Here you go
http://www.shop3m.com/62542203047.html
1990 NA6
Civic Type R
emily_mx5
Postby emily_mx5 » Mon Jul 01, 2013 1:39 pm
Sikaflex
TieNN89
Postby TieNN89 » Mon Jul 01, 2013 6:05 pm
Mr Morlock wrote:it has been used in cars for a very long time and it does its job well.OEM use materials that are functional are not expensive. Its butyl and its quite readily available an example of a maker is Bostik - ref 5214, 5323, 5326, 5331.Check Bostik web site for more info. Its probably at Bunnings and almost certainly at auto paint suppliers.It has multi users for sealing etc. Good plan to use the right product and its useful to have.
I think Mr Morlock is on the money here.
Why do you need it? You should be able to the plastic sheet back onto the stuff that is already on the door.
Mazda used a ridiculous amount of it on my NB8A door and it goes everywhere if you're not careful.
I'm just glad they've gone away from it in the NC
mitch_f1
Postby mitch_f1 » Mon Jul 01, 2013 7:37 pm
I removed it because it had gone everywhere and was just getting on everything so I thought i'd start again. I bought some black mastic (thinking this was the stuff), but it has dried like silicone and is no longer malleable, so it hasn't held the plastic. Now I want something that is sticky and malleable enough that I can remove the plastic and replace it again without putting more mastic on each time.
wassup
Postby wassup » Tue Jul 02, 2013 11:49 am
I've been looking to do the same. It hasn't been easy to get a definitive answer either but I've narrowed it down to the product I previously posted on or the below
1990 NA6
Civic Type R
mitch_f1
Postby mitch_f1 » Tue Jul 02, 2013 6:27 pm
Will give it a shot, thanks Wassup. Also your picture didn't work?
wassup
Postby wassup » Tue Jul 02, 2013 9:57 pm
mitch_f1 wrote:Will give it a shot, thanks Wassup. Also your picture didn't work?
Lets try again :D
3M - 08001 - SUPER WEATHERSTRIP ADHESIVE YELLOW 8001
http://www.ebay.com.au/itm/120721192657?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
1990 NA6
Civic Type R
Drek
Postby Drek » Wed Jul 10, 2013 12:02 am
or if you know anyone in the telecommunications field - Telstra used it to seal the pits on the footpaths sometimes and those vertical joint cylinders etc.. the stuff didn't go hard - exactly the same as car door stuff..
NOTE: don't use any second hand stuff you find because it might have asbestos in it.... :wink:
:beer:
Users browsing this forum: No registered users and 119 guests
