Noise at cold start
Technical Guides primarily to do with the NA series
koolfan
Noise at cold start
Postby koolfan » Thu Jun 13, 2013 3:33 pm
Hi guys. I got a NA8 and after i brought it the next morning when i cold start there are sone squeaky noise for 8-10 secs just wondering what problem do u guys think it is?? is it a major problem as once i drive out and start it again i couldn't hear any squeaky noise. should i go to the workshop to ask them to fix?? the timing belt have been changed before i got it already 140,000 and the odometer is 156,000. cheers.
Roger
NA8, 93
Garry
Re: Noise at cold start
Postby Garry » Thu Jun 13, 2013 6:18 pm
Have you checked the tension on the drive belts? If the timing belt was replaced then there's a good chance the belt that drives the alternator isn't quite as tight as it needs to be. It happens first start in the morning because that is the start that puts the most load on the battery and therefore the alternator to recharge the battery. It's an easy fix if that's the problem. But don't let it go to long or you will glaze the inside of the belt and it will squeal no mater how much tension you put on it.
Postby 93_Clubman » Sat Jun 15, 2013 6:28 pm
If not the drive belt/s, then it might be hydraulic lifter assembly noise, if so change the engine oil.
koolfan
Postby koolfan » Sat Jun 15, 2013 6:38 pm
93_Clubman wrote:If not the drive belt/s, then it might be hydraulic lifter assembly noise, if so change the engine oil.
Hi there the workshop have just change the engine oil and new driving belts include the fan belts but the noise seems to be still there?? Is it because maybe that didn't put the tension on it?? Cheers. Is it possible I could tight them up myself??
NA8, 93
Postby manga_blue » Sat Jun 15, 2013 7:10 pm
New belts often stretch in the first few days and then start squealing on start-up. You could just take it back to the workshop. It should take them 5 minutes. Otherwise you can do it yourself. Suggest you download the NA6 factory workshop manual at http://www.mediafire.com/?7ab5bsnenws155k Password is bcotton.
99% of it applies to an NA8 as well. Drive belt checking/adjustment is on pp 299-300.
koolfan
Postby koolfan » Sat Jun 15, 2013 11:27 pm
manga_blue wrote:New belts often stretch in the first few days and then start squealing on start-up. You could just take it back to the workshop. It should take them 5 minutes. Otherwise you can do it yourself. Suggest you download the NA6 factory workshop manual at http://www.mediafire.com/?7ab5bsnenws155k Password is bcotton.
the link is broken??
NA8, 93
JBT
Postby JBT » Sun Jun 16, 2013 12:00 am
Works for me.
koolfan
Postby koolfan » Sun Jun 16, 2013 12:12 am
JBT wrote:Works for me.
work now :D :D
NA8, 93
koolfan
Postby koolfan » Sun Jun 16, 2013 12:21 am
just wondering what tools do i need to but in order to adjust it??
NA8, 93
Postby 93_Clubman » Sun Jun 16, 2013 11:50 am
Spanner/s.
Again, if noise persists after belts are correctly adjusted, the NA6 & NA8 (which both had HLA) can be a little fussy about oil as they age, but a number of forumites have used Nulon Lifter Free successfully.
koolfan
Postby koolfan » Sun Jun 16, 2013 12:27 pm
93_Clubman wrote:Spanner/s.
HLA?? the Nulon Lifter u mention is a type of oil??
NA8, 93
Postby 93_Clubman » Sun Jun 16, 2013 12:35 pm
= HLA
Nulon Lifter Free is an additive.
koolfan
Postby koolfan » Fri Jun 28, 2013 2:50 am
anyone are near rhodes, 2138 would give me a hand?? as i am really noob are this case.
NA8, 93
rosco
Postby rosco » Sat Feb 15, 2014 3:02 pm
BIG thanks from Rosco. been trying everywhere for the w/s manual download.CHEERS.
Return to “NA [1989 - 1997]”
