Post your turbo / supercharged setup
Re: Post your turbo / supercharged setup
Postby Okibi » Wed Jun 12, 2013 10:06 pm
Looks epic! :mrgreen:
Hjt
Postby Hjt » Wed Jun 12, 2013 10:45 pm
looking forward to your return to the track Cameron
Postby Okibi » Thu Jun 13, 2013 8:44 pm
Nope not mine but thought i'd share for lols.
Postby Jeo » Thu Jun 13, 2013 11:06 pm
Damn it Dann. You really need to pick up your game man...
Postby NitroDann » Thu Jun 13, 2013 11:18 pm
Thats the one I built for MX5+s demo car, cant let them beat me now can I!
chops
Postby chops » Fri Jun 14, 2013 12:00 am
Thanks for the kind words
Coils are M&W and I am really keen to get back to the track will hopefully be at smsp in July
bootz
Postby bootz » Fri Jun 14, 2013 12:15 am
chops wrote:picked it up this morning in the wet with no roof and track tyres, bit of a handfull
Holy rear wheels KW! This is one hot turbo.
Sean
Postby Sean » Sat Jun 15, 2013 1:06 pm
So that's 290hp odd - Solid clean looking tune judging by the graph - Assuming it's on 98 too not eflex??
Postby NitroDann » Sat Jun 15, 2013 1:47 pm
A bit of boost control bounce but yes it's very clean.
2L and a big turbo also.
Postby Okibi » Sat Jun 15, 2013 2:09 pm
chops wrote:..
That's a PWR Twincooler? Did you have any trouble fitting to the SE?
chops
Postby chops » Sat Jun 15, 2013 2:19 pm
yeh that is a PWR twin cooler, only problem we had with fitment was the oil line fouling on the cooler pipe. I have turned the fitting towards the centre of the car more since that photo and clears happily
tuned on BP 98, not 2L though. Bought a brand new block after i broke a rod and is 20 thou over
it is taking some learning to drive
Postby NitroDann » Sat Jun 15, 2013 2:48 pm
chops
Postby chops » Sat Jun 15, 2013 3:36 pm
interesting, every online calculator i looked at does not take into account combustion chamber. my knowledge is pretty limited in this area but by using that method a standard engine size is 2046cc (as opposed to 1839cc factory stated) and mine is 2091 so a "gain" of approximately 50cc?
Postby NitroDann » Sat Jun 15, 2013 4:07 pm
What you are saying is spot on and totally correct. You are referring to swept volume not total capacity.
What's nice about cars with artificial aspiration is that unlike an n/a car the combustion chamber is also filled.
Regardless you have an 1850 nine it another 50cc it's damned close to 2L.
I wasn't trying to say you a are cheating or anything it just helps explain why the car does such a great job of spooling that big turbo as opposed to something like charlie's old car or pats car.
Sean
Postby Sean » Sat Jun 15, 2013 6:01 pm
While capacity helps, it just looks like a well considered system build with clever things that I suspect were thought out rather than guessed at.
Short manifold with a heavy casting will keep the exhaust to the turbo hotter than many set-up and spool like a beast while not having a great effect on top end.
Intake generally costs these more power than exhaust manifold, and that looks well catered for here too.
Regardless of anything else, that graph looks solid, the boost bounce would likely be slightly improved on the road vs dyno, and could be attributed to a number of things, particularly a cheap boost controller (not sure what's on this car though).
Should have plenty more left in her too - But I'd bet my broken retaining wall it's a pleasure to drive 8)
