Post your turbo / supercharged setup
Re: Post your turbo / supercharged setup
Postby NitroDann » Sat Jun 15, 2013 1:47 pm
A bit of boost control bounce but yes it's very clean.
2L and a big turbo also.
Postby Okibi » Sat Jun 15, 2013 2:09 pm
chops wrote:..
That's a PWR Twincooler? Did you have any trouble fitting to the SE?
chops
Postby chops » Sat Jun 15, 2013 2:19 pm
yeh that is a PWR twin cooler, only problem we had with fitment was the oil line fouling on the cooler pipe. I have turned the fitting towards the centre of the car more since that photo and clears happily
tuned on BP 98, not 2L though. Bought a brand new block after i broke a rod and is 20 thou over
it is taking some learning to drive
Postby NitroDann » Sat Jun 15, 2013 2:48 pm
chops
Postby chops » Sat Jun 15, 2013 3:36 pm
interesting, every online calculator i looked at does not take into account combustion chamber. my knowledge is pretty limited in this area but by using that method a standard engine size is 2046cc (as opposed to 1839cc factory stated) and mine is 2091 so a "gain" of approximately 50cc?
Postby NitroDann » Sat Jun 15, 2013 4:07 pm
What you are saying is spot on and totally correct. You are referring to swept volume not total capacity.
What's nice about cars with artificial aspiration is that unlike an n/a car the combustion chamber is also filled.
Regardless you have an 1850 nine it another 50cc it's damned close to 2L.
I wasn't trying to say you a are cheating or anything it just helps explain why the car does such a great job of spooling that big turbo as opposed to something like charlie's old car or pats car.
Sean
Postby Sean » Sat Jun 15, 2013 6:01 pm
While capacity helps, it just looks like a well considered system build with clever things that I suspect were thought out rather than guessed at.
Short manifold with a heavy casting will keep the exhaust to the turbo hotter than many set-up and spool like a beast while not having a great effect on top end.
Intake generally costs these more power than exhaust manifold, and that looks well catered for here too.
Regardless of anything else, that graph looks solid, the boost bounce would likely be slightly improved on the road vs dyno, and could be attributed to a number of things, particularly a cheap boost controller (not sure what's on this car though).
Should have plenty more left in her too - But I'd bet my broken retaining wall it's a pleasure to drive 8)
bootz
Postby bootz » Sat Jun 15, 2013 6:03 pm
NitroDann wrote:A bit of boost control bounce but yes it's very clean.
What shows that, the wiggles at the start of the torque plateau?
All I know about dyno sheets is that this one has a nice fat kw figure for an NB turbo. It is also has a nice flat power curve and a flat torque curve. I would like to see the Air/Fuel ratio readout as well.
Postby NitroDann » Sat Jun 15, 2013 6:49 pm
The bottom graph is a boost pressure graph.
bootz
Postby bootz » Mon Jun 17, 2013 8:25 pm
NitroDann wrote:The bottom graph is a boost pressure graph.
Yep, I know bugger all about dyno charts and about the same for turbos.
Postby Okibi » Tue Jun 18, 2013 1:38 am
Here's one of Simon's SE.
Rorge
Vehicle: NA6 - Turbo
Postby Rorge » Sat Jun 22, 2013 12:06 am
I made a new dump for my NA6-T28 setup which came out ok, did some hillclimbs with worn out RSR's..
https://www.facebook.com/video/embed?vi ... 8517852587
Then broke a couple of gears in one of many 5 speeds, fitted a 6speed and finally got a fresh tune from a mate in Sydney who's pretty good with Haltechs..(running an E8) It's running a 4.11 torsen so it's very short with the 6speed! 3500rpm @ 100km/h in 6th.
Engine bay with old 2.5" dump..
Dump
2 hours later with a hammer and using my Triton Superjaws as a vice and dolly I got this result..
Tune was on pump fuel and 550cc RX7 Injectors. (i'll switch to ID1000's when Ethanol is more readily on the pump. For now the car drives very smooth but lumpy idle 1000-1100rpm as the injectors don't appear to be able to pulse close enough together. It drives GREAT other than the wheelspin in 3rd if i'm a little hamfisted...
Postby NitroDann » Sat Jun 22, 2013 12:17 am
Awesome job, looks like a downpipe or 2 I made before :P
Its hard work to cold work that flange shape isnt it !
Rorge
Postby Rorge » Sat Jun 22, 2013 1:20 am
It was tricky but kinda like meditation! I love making stuff! (i'm just really crap at it) That's why I built this home-made $hitbox! :)
The exhaust manifold looks alot 'tidier' than that after I chopped off the whole base of the merge/flange and used some new thick wall pipe to make it stronger/cleaner.
PaulF
Postby PaulF » Sat Jun 22, 2013 4:38 am
Facebook video link doesn't work for me; do you have it set to public?
Users browsing this forum: No registered users and 97 guests
