Painting Calipers Again....
gslender
Re: Painting Calipers Again....
Postby gslender » Wed Jun 05, 2013 7:06 pm
fastfreddygassit wrote:...... as extended use in the wrong position will ultimately lead to seal failure (blown shocks).
The best way to tell is:
1. Obviously read the LHS and RHS label on the base of the shock;
2. The spring spiral orientation should follow the direction of travel.
That is, the downward right to left coils should be on the LHS and the downward left to right coils should be on the RHS.
Interesting. Is this the case for all coilovers? I've not heard of it nor seen any manufacturers making a big deal out of it to ensure they are installed correctly.
gslender
Postby gslender » Wed Jun 05, 2013 8:08 pm
Hmmm, after sending an email to HSD in the UK, apparently this shock orientation is correct... I'd best check mine as I didn't notice the LHS/RHS under the mounting knuckle.
I love this forum, you learn stuff every day.
G
Postby fastfreddygassit » Wed Jun 05, 2013 10:37 pm
gslender wrote:Hmmm, after sending an email to HSD in the UK, apparently this shock orientation is correct... I'd best check mine as I didn't notice the LHS/RHS under the mounting knuckle.
G
It's something that a lot of people miss. I picked this tip up from the motorsport guys and the same info is on the US forums too.
Users browsing this forum: No registered users and 349 guests
