performance parts?
MXO00V
performance parts?
Postby MXO00V » Sun May 26, 2013 10:58 pm
where does everyone get there parts from?
i have a mx5 NB8b
im looking online at the moment at a store in canada :|
Miata Intake Manifold Heatshield gasket Hondata $49.00
1 Racing Beat Header $425.00
1 Denso 195500-4450 injectors $279.00
1 Skunk2 Throttle Body Miata 94-05 $325.00
Subtotal $1,078.00
then close to 400 for shipping :|
MXO00V
Re: performance parts?
Postby MXO00V » Sun May 26, 2013 11:29 pm
now looking at miataroadster.com
can anyone help?
PaulF
Postby PaulF » Sun May 26, 2013 11:44 pm
Shipping from the US is usually pretty expensive. It might help if you explain why you're getting those specific parts. What are your plans for the car?
MrRevhead
Postby MrRevhead » Sun May 26, 2013 11:48 pm
Try a freight forwarder for shipping.
Consider http://www.shipito.com/
Consider a possible 15% on top of purchases >$1000 factoring GST + custom fees.
If the company you purchase from can write off that the product was manufactured within the US or as a product <$1000, you may avoid GST + custom fees.
MXO00V
Postby MXO00V » Sun May 26, 2013 11:54 pm
Just want to get some more n/a gains its probably been said alot before lol
Eventually going to turbo in a couple years
Been thinking of getting a flattop intake manifold, injectors, CAI
and a megasquirt pnp already talking to gslender about one I just want to get everything ready before the ecu
Sent from my GT-N7105T using Tapatalk 2
MrRevhead
Postby MrRevhead » Mon May 27, 2013 12:01 am
BTW all the parts you have listed above will not gain you much power at all in terms of $$$ outlay.
I highly suggest you research a bit more prior to outlaying some $$$ on mods.
(I don't intend to offend as that is not my intention, but I honestly think more research will gain more bang for buck compared to what you're prepared to spend for the above mods).
Postby NitroDann » Mon May 27, 2013 12:02 am
Stock na6 throttle body and intake manifold is good for at least 325wheel HP.
Been there done that.
There I just saved you $325 :mrgreen:
MXO00V
Postby MXO00V » Mon May 27, 2013 12:12 am
I do research but people will always say yes it does and no it doesnt online.
people say on a n/a setup with a bigger throttlebody and CAI thats about 10hp with tune of course
Dont worry your not being rude
MrRevhead
Postby MrRevhead » Mon May 27, 2013 12:26 am
Consider the bang for buck value on your suggested mods.
10HP for $1400.
Personally I would consider spending my money on other things besides gaskets and a throttle body that won't yield any gain in power, let alone the associated shipping and customs and tax duties associated with obtaining them.
If you must, a well thought out cat back exhaust and $50 replica Mania intake will yield you close to or the same power for about a 1/3 of the outlay.
Sent from my Galaxy Nexus using Tapatalk 2
MXO00V
Postby MXO00V » Mon May 27, 2013 12:49 am
I have a hiflow cat 2.5inch pipe to a kakimoto HYPER FULLMEGA N1 + Rev exhaust
what else would you recommend? i am all ears cause it is good to hear from peoples trial and error
port and polish the head? heard there isnt great gains from that either good for FI though
Postby NitroDann » Mon May 27, 2013 12:55 am
The best fuel you are willing to run (e85 if you are willing)
The most compression that the fuel you choose will support.
BIG cams.
That is the path to power.
sailaholic
Postby sailaholic » Mon May 27, 2013 7:44 am
Headers, intake ecu, after that your wasting your time if your going boost.
If you want to go na next is cams
Then head work
Then built bottom end and review the headwork and cams again. At this point it would have been cheaper to add boost.
Steampunk
Postby Steampunk » Mon May 27, 2013 12:24 pm
More research needed as the RB headers are the only thing on your list that I would have considered way back when I started modifying my old car.
Bigger injectors is not a "performance" part per se either, they are only needed if your car is making considerably more power hence need more fuel.
You don't just put in bigger injectors and voila!.... more power.
MXO00V
Postby MXO00V » Mon May 27, 2013 12:39 pm
Was looking at cams not many to choose from cause vvt
Thought I would do injectors aswell for when I decide to turbo or wouldnt they run properly while in n/a application
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Mon May 27, 2013 12:45 pm
MXO00V wrote:I do research but people will always say yes it does and no it doesnt online.
you will lose power with that throttle body unless you are pushing a lot more power.
http://forum.miata.net/vb/showthread.ph ... ght=skunk2
