Acrylic paint on intercooler pipes
trader
Postby trader » Fri May 24, 2013 6:07 pm
My inter ooler pipe from supercharger has marks on it and I want to clean it before reassembly. It is powder coated . I intend to prime it and then acrylic spray can. Has anyone tried this or can comment on whether the heat will be too great for acrylic. I could just try it but would rather be confident and not have to pull it apart again. I know, I should just get it powder coated again but like having my own touch.
NB SE, NA 1.8.
Apu
Re: Acrylic paint on intercooler pipes
Postby Apu » Fri May 24, 2013 7:40 pm
Depending on colour, why not use high temp paint?
trader
Postby trader » Sat May 25, 2013 10:49 am
Ther is only one pipe damaged and I have got acrylic which matches the others...
NB SE, NA 1.8.
Postby Mr Morlock » Sat May 25, 2013 12:47 pm
If it is a high heat location and you do not use a high heat paint it will fail.
droo
Postby droo » Sat May 25, 2013 2:19 pm
Assuming your painted surface isn't almost rubbing against a 900 degree C exhaust manifold.
Using a hi temp resistant primer base you can then paint any colour colour acrylic of your choice over the top. you *might* get discolouration if the colour is not dark, but the heat resistant primer will keep the paint bond to the primer (and pipe) ok.
trader
Postby trader » Sun May 26, 2013 10:06 pm
Thanks mate - going to give it a try.
NB SE, NA 1.8.
Users browsing this forum: Bing [Bot] and 66 guests
