Fuel consumption on the track?
Re: Fuel consumption on the track?
Postby manga_blue » Tue May 21, 2013 5:57 pm
rascal wrote:Is that how you justify it to the missus?? Honestly honey, I'm saving us money by getting an ECU...
You know you can't do that, Russell. Anyone who claimed a payback on just one mod is then wide open to questions about a cost/benefit analysis and payback period on every other mod. Even mentioning that the fuel consumption is so much better after the ECU invites a query about how much fuel were you using before the ECU. Relationships can be clouded by too much detail.
mazmad
Postby mazmad » Tue May 21, 2013 6:31 pm
Sounds about right. Thanks.
Hellmun
Postby Hellmun » Tue May 21, 2013 8:00 pm
From brimmed to the top to spluttering at the fish-hook I managed 66 laps at wakefield in the 300 a few years ago. That was 0.57 litres per lap assuming I got exactly 40 litres in it. Mine made 90kw...though I'd have to go dig out that dyno sheet to see what my AFR's are like.
mazmad
Postby mazmad » Tue May 21, 2013 9:11 pm
mazmad wrote:Sounds about right. Thanks.
That was directed at Charlie Brown. Although it also applies to manga blue......'need to know basis' approach works best for me. And I definitely do not need her to know. :D
evil_weevil
Postby evil_weevil » Fri May 24, 2013 7:55 am
No idea what my nugget does but easily half a tank for full day MRA.
My old r33...tank for just a supersprint!
viewtopic.php?f=73&t=62834
stb
Postby stb » Fri May 24, 2013 2:11 pm
I'm around 36l/100km on track - NB8C motor running on e85 (no boost). Lines up with most people's ~25-28l/100km on 98.
mazmad
Postby mazmad » Fri May 24, 2013 2:42 pm
Cool thanks.
Postby Magpie » Fri May 24, 2013 3:38 pm
stb I have been pondering my fuel supply since I'm going to run E85 and if a standard NA will have enough to do a 1 hour with no refueling. My plan is now to swap the NA6 for a NA8 tank and put a 5 ltr surge tank in the boot.
stb wrote:I'm around 36l/100km on track - NB8C motor running on e85 (no boost). Lines up with most people's ~25-28l/100km on 98.
zero00
Postby zero00 » Sun May 26, 2013 11:57 am
I've done the sums for my NB8A from the Track Day last Monday at Queensland Raceway
Total from 'fill to fill' = 39.3 Litres for 387km
Track kilometres = 109
Road Kimometres = 279
Based on an average for 'road kilometres' of 7.5L/100km it calculates at:
20.9 litres for 279km = 7.5L/100k
18.4 litres for 109km = 16.88L/100km
Roger D-SUNSHINE COAST
project.r.racing
Postby project.r.racing » Sun May 26, 2013 12:13 pm
Magpie wrote:stb I have been pondering my fuel supply since I'm going to run E85 and if a standard NA will have enough to do a 1 hour with no refueling. My plan is now to swap the NA6 for a NA8 tank and put a 5 ltr surge tank in the boot.
get a 10L surge tank if you are allowed to run that bigger size.
E85 drinks 33% faster then regular fuel.
track use is 3 times the fuel you use on road use, rough guide. so about 24-27L/100km for regular fuel, so add 33% for E85 = 32-36L/100km. goes in line with an earlier post.
so every 5L you can gain, gives you 14km (on E85) track usage. so 5 to 7 laps extra at most tracks roughly.
stb
Postby stb » Tue May 28, 2013 2:07 pm
Having done some long runs recently for modern regularity, an hour is probably possible with NA8 tank. I was using ~2/3 of a tank in ~45 minutes of running. Other MX5s were running 1.5 hour stints without refueling, so in theory at least 1 hour should be possible on e85.
Users browsing this forum: No registered users and 69 guests
