ASI radiator issue!?
- Vehicle: NB Roadster
WINTON PB - 1:57.4000
Re: ASI radiator issue!?
nitrodann should hopefully be able to shine his light of knowledge on this issue.
Turns out I was right, huh.
the radiator is not jdm dann
- timk
Can you take a lower picture where the gap is under the filler neck?
timk wrote:Can you take a lower picture where the gap is under the filler neck?
I will try tommorow.
Although now it doesnt matter too much as my replacment rad should be here tommorow
top quality ASI check out all the satisfied customers.
Ill be the first to admit I regret that purchase
- MrRevhead
You should of bought a JDM one, like a Calsonic.....
As with all items, there will always be a a failure/exception to quality. One faulty example vs many others who have had great success with ASI's is nothing to go by.
Narita, I assume you got a replacement under warranty since you purchased yours not too long ago?
- Red Dragon
As well as being a Curmudgeon Morlock is Sarcastic as well
- Aussie Stig
- Stig
Red Dragon wrote:As well as being a Curmudgeon Morlock is Sarcastic as well
Still look at those welds, luvverly, who cares if it leaks. JDM points.
MrRevhead wrote:You should of bought a JDM one, like a Calsonic.....
Yep! I understand that the quality control must be quite poor for them to push them out for the cheap asking price and to be fair there after sales support was very good.
I hope this new one holds together a bit better!
Time to cook up some of my famous 70/30 mix!
- Jeo
Mr Morlock wrote:top quality ASI check out all the satisfied customers.
Top snipe there Mr M. Full points.
Are we circle jerking again?
Users browsing this forum: No registered users and 46 guests
