Went on a pleasant drive to my partner's grandsons 5th birthday today,bit of a problem,couldn't open the boot to get the presents out!!
Cannot open it with the lever,which seems to come up a fair way before doing anything but will not open with key as well despite jiggling .pulling etc .
There is a certain amount of noise as though the cable is doing something,but the fact that the key doesn't work either is a worry.
Anyone had this drama ?Any suggestions?
Car is a 96 NA8A.
Peter.
Boot won't open
- pcmx5
- Vehicle: ND - 2
Boot won't open
Re: Boot won't open
Thing in the boot are probably pushing hard against the mechanism, you can try doing a hard stop and shifting the things in the boot.
- aka_juffa
Re: Boot won't open
Hi Peter,
You have probably tried this....When the lever or key won't pop the boot I push down on the boot lid as I turn the key. Usually works if there is something big in the boot that is pushing up against the boot lid.
Good luck.
J.
Good luck.
J.
Re: Boot won't open
there was a long post on this a few years ago. I suggest give the MX5 Factory a call- if anyone knows they probably do.
Re: Boot won't open
If you don't keep the spare in the boot, you can remove the panel behind the seats to get a good view and some access to the boot area. Just remove the rear parcel shelf carpet, and the nuts holding the largest panel and you should be good to go. Abit of a faff but it should at least give you a good view of what might have gone wrong.
You might also be able to shift things in the boot by jacking the car up, up until a point where the angle is great enough for things to move around.
- 16bit
Re: Boot won't open
aka_juffa wrote:Hi Peter,
Good luck.
J.
what he said, worked for me in the past without anything in the boot too.
- pcmx5
- Vehicle: ND - 2
Re: Boot won't open
Thanks all for your advice, been up to my elbows replacing weatherboards so haven't got to the boot problem again. Have tried the push and turn and wiggle and turn jobs before I posted with no success.
Thinking of removing console and trying to take out slack in the cable and driving over bumps while pulling the lever or backing over the rear lane centre gutter to provide some twist.
itungs , I have the spare in position so does this make your solution useless?
Thinking maybe I caught a cloth handle from one of the bags in the mechanism as there really isn't a heap of stuff in there.
Thanks again and keep the ideas coming, will let you know how I go .
Peter
Peter
Re: Boot won't open
Unfortunately my solution is pretty useless with the spare in the boot.
- funmx5
- pcmx5
- Vehicle: ND - 2
Re: Boot won't open
Jason, off to MX Factory in the morning to do the drill behind the number plate job.Fingers crossed!
Peter.
Peter.
- aka_juffa
Re: Boot won't open
Ouch. Thats a long drive, Geelong to Ringwood. Remind Dick not to drill too far into the boot...don't want to ruin the present trapped in there.
J.
J.
- pcmx5
- Vehicle: ND - 2
Re: Boot won't open
Mystery solved! Great service from Dick at MX5 factory.Drilled the hole ,got the rod to the lock and pulled .....nothing!
Dick went under the car and took out one of the drain plugs fron the boot floor and found there was something caught in the lock.After a bit of tugging they retieved my brand new vest minus part of the metal zipper which I had managed to catch in the jaws of the locking mechanism.
Moral of the story, always make sure the lock is clear of any objects before closing the boot.
Thanks to Dick and all who contributed advice.
Peter.
Peter.
- taminga16
Re: Boot won't open
pcmx5 wrote:Mystery solved! Great service from Dick at MX5 factory.Drilled the hole ,got the rod to the lock and pulled .....nothing!
Peter.
Hi Peter,
Zippers caught in things, with my middle boy it was always thing caught in zippers (He was always in a hurry). Would it be prudent to create a drilling template and post it somewhere here?
Greg.
- funmx5
Users browsing this forum: Google [Bot] and 119 guests
