1.8 torsen into 90 na6.
CheyneX5
Re: 1.8 torsen into 90 na6.
Postby CheyneX5 » Fri May 10, 2013 4:21 pm
You need to also get drive shafts from an NB. The tail shaft is also different.
90' NA6 - Classic Red
CheyneX5
Postby CheyneX5 » Fri May 10, 2013 4:22 pm
Also, if you are only changing the diff, you will find that running a 3.9 make the cal feel slower and each gear will feel taller.
The correct ratio for an NA6 is 4.3.
Jace
Postby Jace » Fri May 10, 2013 5:11 pm
you need to push them in far enough for the circlips to pop into the diff center.
try holding each shaft straight and giving it a good hit with a dead blow hammer/mallet.
don't push them in too far though, or you can damage the output seals and rip the outer ends off the driveshafts. ask me how i know. :roll:
Postby NitroDann » Fri May 10, 2013 8:58 pm
CheyneX5 wrote:Also, if you are only changing the diff, you will find that running a 3.9 make the cal feel slower and each gear will feel taller.
The {original} ratio for an NA6 is 4.3.
FTFY
Steampunk
Postby Steampunk » Fri May 10, 2013 9:14 pm
Did you also get the appropriate speedo sender from the gearbox?
trader
Postby trader » Sat May 11, 2013 3:58 pm
I had the same problem - to get the circlips to remain centred I put a bit of grease on them. I have a speedo sender if you need one.
NB SE, NA 1.8.
Jace
Postby Jace » Sat May 11, 2013 6:48 pm
speedo in an na6 is closer to accurate with a 4.1:1 than 4.3, if you trust speed sensors signs.
indicated 100km/h is more like 102km/h than 94km/h, with a 4.1 on 185/60 14".
trader
Postby trader » Sun May 12, 2013 2:14 pm
Apparently there is only two types. The spare I have is purple and has 22 teeth. Should only take a minute to check yours out. Fits both na and nb box but didnt suit me as I have a weird speedo. You may have to do what I did by advancing speedo needle to 10 kms when stationary. let me know how you go.
NB SE, NA 1.8.
tomli123001
Postby tomli123001 » Sun May 19, 2013 10:48 pm
I did this to my car just last week at MX5plus by Jason there.
Two ways you can go about it. 1. buy an adaptor kit, as the attachment mount is different between NA6 and NA8.
2. Buy a used NA8 subframe with brakes hubs and control arms. The the diff will fit in just like at home.
I went with the 2nd option, bought a complete rear sub frame off MX5plus. They had tons of these on the rack. Guess you could do cheaply at a lucky wrecking yard, as not many people took the subframes, ,after the diff is sold off.
NA6-Rolled off Mt Nebo
NB SE-Sold for investment property deposit, then crashed by the buyer months later
Now Black NB SP #31.
gslender
Postby gslender » Mon May 20, 2013 9:43 am
Really? You need the entire 1.8 subframe? I've seen/heard plenty of folks install a 1.8 diff into a 1.6 and all they needed was the shafts? What's this about needing the entire subframe or some adapter plate? What specifically for?
G
Sean
Postby Sean » Mon May 20, 2013 11:08 pm
gslender wrote:Really? You need the entire 1.8 subframe? I've seen/heard plenty of folks install a 1.8 diff into a 1.6 and all they needed was the shafts? What's this about needing the entire subframe or some adapter plate? What specifically for?
G
Yeah, news to me. You need the aluminium Y frame hanger bit that houses the diff, the side shafts (potrentially hubs delepnding on shaft types) and the main drive shaft....
I've done two like that unbolt old one, bolt in new one. No subframe, no special modded bits.
