Postby Mr nanotech » Tue May 07, 2013 3:48 pm
When you say things like 'dynamics' and 'aero' do you actually know what you are talking about and have a practical application in mind or are you chasing down some the pretty up your street car?
As for carbon fibre, there is little to no benefit fitting a carbon bonnet to an mx5 as the stock one is already light alloy to begin with. The bootlid however is steel and can be replaced with a lighter alternative but even then, you are just chasing your tail if you haven't ripped everything else out of the car and lightened up as much as possible first.
Have a look at autokonexion online and check their bonnets. You might find something you like. For the street I wouldn't bother with aero, you aren't driving at a consistent speed since there are limits, traffic, road hazards and so on. Any aero benefits would be lost as a result unless you want something to vent excess hot air out of your bonnet etc. Say, if you were running a high psi turbo or s/c setup which may generate a lot of unnecessary heat.
