NitroDann's Long Awaited Garage Thread
16bit
Vehicle: NB8A - Supercharged
Re: NitroDann's Long Awaited Garage Thread
Postby 16bit » Thu May 02, 2013 9:45 am
i tried to convince him of off the shelf stuff but no dice.
Postby NitroDann » Thu May 02, 2013 5:56 pm
tried to convince lokiel to not buy my manifolds !!!
Thems fightin' werdz :lol:
Here is some bits, the Forge actuator getting turned down in the lathe so it can be threaded further up the shaft to fit properly, I assume this actuator is designed for a slightly longer EFR turbo.. otherwise it would have been threaded further or had a shorter shaft.
And then a reroute pipe to go with the Begi spacer and modified front housing and a welsh plug to replace the front thermostat housing (pipe only pictured)
Upside down sorry
Apu
Postby Apu » Thu May 02, 2013 10:13 pm
Dann, can you build me a reroute pipe since you've got a template now please?
A.Chen89
Postby A.Chen89 » Thu May 02, 2013 10:43 pm
Apu wrote:Dann, can you build me a reroute pipe since you've got a template now please?
great minds think alike!
Postby NitroDann » Thu May 02, 2013 10:54 pm
Post un-instagramed picture of your bay and I will decide :)
Apu
Postby Apu » Thu May 02, 2013 11:07 pm
You know what it looks like! We can move some of the oil cooler hoses.
Postby NitroDann » Thu May 02, 2013 11:10 pm
Yeh its the hoses.
Postby Lokiel » Thu May 02, 2013 11:14 pm
16bit wrote:i tried to convince him of off the shelf stuff but no dice.
If I bought an off-the-shelf GT2650 kit, I knew that I'd always regret not getting the EFR6258 instead, it spools much faster and generates more power than the GT2560.
Now that it's almost complete, I'm glad I did, it's friggin' awesome!
sailaholic
Postby sailaholic » Fri May 03, 2013 7:44 am
Having spoken to you in person I can honestly say I think you will be disappointed about 2 months after you've got this back......
Because it still has stock bottom end and knowing you, you will want more! Haha :grin:
Postby Lokiel » Fri May 03, 2013 9:07 am
Not for long :P
Unfortunately until then, it will be like sleeping in the same bed as Salma Hayek but not being able to touch her until the engine is built.
bootz
Postby bootz » Fri May 03, 2013 1:26 pm
Thanks Dann, you can learn a shitload round here. For ref, here is the AVO 1.6 mani.
Postby NitroDann » Fri May 03, 2013 5:59 pm
It should do over 400 atw with a built bottom end if i did my job right.
He wont get bored of that haha :twisted:
Postby NitroDann » Fri May 03, 2013 6:34 pm
Manifold is currently at the ceramic shop getting a couple of coats of Turbo X ceramic coat. Build to handle 2000c and keep the heat and therefore turbo spooling energy IN.
Postby NitroDann » Mon May 06, 2013 9:45 pm
Some bits and pieces.
Reproduction rear brace for Earlybird.
noobee
Postby noobee » Mon May 06, 2013 11:31 pm
need a mania one to measure up from?Ken bought me a set for christmas but I only put the front on :wink:
Mick
